GR Yaris World premiere of GR GT3 Concept and fully tuned model of the GR Yaris
The wheels on the grey/white one look nice (different to standard CP BBS?) as do the seats. Not so keen on the add-on splitters and wings etc. on it though.
Quite like the instrument cluster too. Mabe looks like it has a nice alcantra wheel and gear knob.
Tbh this is a bit of dream come true for the Germans. Since all of those parts are OEM it will be very easy to get the parts put into the papers.
Especially the Recaros without Airbag will be able to be used as proof that "even Toyota considers the car to be safe enough without" - since this is always a point of discussion when putting in Seats without a Side Airbag.
If you look at the interior photos, you’ll see that the PP’s are fitted with airbags. So unfortunately that argument doesn’t hold.
+1, at least in Finland it is illegal to remove any safety equipment from a car. It is different story if you have a model without spesific airbag, but with GR I presume they all have.
It will,take a look at the photos of the Rally Package :)
If I'm not blind there are not Airbags there.
In Germany it is also illegal if you cannot prove that the safety doesn't get worse by removing this specific bit of equipment.
If the replacement is OE equipment though that usually changes everything..
guck mal
I've seen this, there do seem to be two different Versions out there though.. One with Airbags and one without... Maybe that's just a misunderstanding on my part though :)
Honestly I'd be happy to take those Recaros with or without Airbags anyway! :ROFLMAO:
Its good to note that Toyota claims different service requirements and warranty for GRMN. Traslating directly with google translate (from precautions before purchase).
Quite a bit different than what Toyota 10yr extended is at the moment.
Sorry fo mess..
Please note that GRMN Yaris has a different warranty period from other Toyota cars. * 1 Item Items Items to note Category Item Items Items to note Category General Drive system Chassis vehicle Interior 1 Maintenance Manual transmission, Differential (new car 1000km Oil change while driving) Inspection and manual transmission oil in GR garage when traveling 1,000km, rear Change the differential oil. (Manual transmission, rear differential It is recommended to perform inspection and replacement in the GR garage. The replacement cost will be borne by the customer. 2 Maintenance Manual transmission, Rear differential Use the specified oil (compatible with mechanical LSD). 3 Maintenance Rear differential The oil change cycle should be every 5,000km. 5 Precautions Reinforced clutch We are using a metal clutch. Depending on how the clutch is engaged when starting, Vibration (judder) / abnormal noise (squeal) may occur, but this is not a malfunction. Rapid operation (rapid clutch engagement) until the condition of the friction surface stabilizes (about 500 km in the city) Please drive while avoiding driving at full throttle. 4 Precautions When replacing the flywheel clutch, if there is a lot of wear, it may be replaced at the same time. 6 Precautions Transfer 5000km break-in is recommended. (Driving avoiding sudden acceleration and deceleration) 7 Precautions Tires Since the tires are specialized for exercise performance, they may wear quickly. 8 Precautions Tires have a dry grip priority design. When it rains, slow down sufficiently and try to drive safely. 9 Precautions important point Tires The gap between the tires and the body is narrow and the chain cannot be attached. 11 Precautions Do not adjust the height of the shock absorber. It is not covered by the warranty. (It is assembled to the vehicle after adjusting to the optimum condition) 10 Aluminum wheels The aluminum wheels in the circuit package are matte painted. May be glossy Therefore, clean it only with a neutral detergent, and avoid using wax or cleaners. 12 Precautions Since the minimum ground clearance is low below the vehicle, avoid using a mechanical parking lot or stopping from the front. 13 Maintenance Steering wheel If you experience the shine that is peculiar to the suede skin, spray it with water. 14 Maintenance Parking Brake Lever If you experience the shine that is peculiar to the suede skin, spray it with water. 15 Care Shift Lever Knob If you experience a shine that is peculiar to the suede epidermis, spray it with water. 16 Attention Front pillar garnish, Defroster garnish Due to the flocked coating, there is a risk of leaving marks if touched. Please handle with care 17 Precautions RECARO Seat height, angle, and seat belt adjustment require tools, so please consult your dealer. 18 Care RECARO Sheet If you experience the shine that is peculiar to the suede skin, wipe it with water. 19 Precautions RECARO sheet Aged deterioration may cause wrinkles, shine, etc. 20 Precautions Rear seat (without seat) Not designed as a luggage storage area. Please do not carry luggage / people. 21 Attention Center outlet (When the optional center cluster is installed) The air conditioner wind from the center part is difficult to reach the head. 22 Precautions Carbon bonnet (CFRP) Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Due to the characteristics of the material, you may see swells and shades of the twill pattern. There is no quality problem. Also, if you are exposed to ultraviolet rays for a long time, the color may change. We recommend storing it in a place that is not exposed to the sun. Please refrain from using the car wash machine as the GT wing may get caught. 23 Attention Carbon roof (CFRP) 24 Precautions Rear spoiler (CFRP) 25 Precautions Matte gray paint Do not use wax containing alkaline or abrasives as it may cause gloss. Guarantee 26 Warranty Front Differential 27 Warranty Rear Differential 28 Warranty clutch (cover / disc / release cylinder simultaneous replacement) 29 Warranty shock absorber 30 Warranty steering wheel * 2 31 Warranty parking brake lever * 2 32 Warranty shift lever knob * 2 33 Warranty Front Spoiler 34 Warranty Side Mudguard * 3 One year from the date of new car registration. However, even within that period, he has a mileage of up to 20,000km. Exterior
I like the seats, front badging... I don't like the wing... looks like a utility vehicle lol... 🤨
Interesting though... would love to know more and if any other country would get a sniff of it but as you say, totally Japan only specials... our cars are quite special anyway! 🥰 😜
I think the issue is that the Circuit version is an official model with manufacturers warranty etc.. However, the “rally” version is a package that can be ordered through the stealership, but will essentially be a modified car and will have to be MOTd with the changes. Or at least that’s how I understood the press kit.
That is entirely possible. The buckets with the airbags will certainly be allowed but there is a risk that the buckets without won't be accepted.
In the end that decision is up to the TÜV-Engineer that checks your vehicle.. I suspect this would be a difficult call to make since the parts are still from Toyota but it is an aftermarket package..
Uk have snapped up as many as Toyota can give us and more, why wouldn’t they consider supplying the UK and rest of the world with some editions , this time they would be making some money on them
I'm happy with my GR and won't be losing any sleep over the GRMN.
I think it's great if you are 1 of the lucky 500 in Japan and are happy to pay the extra, but how many will actually be driven regularly? Anyone overseas who imports one is going to be looking at £70k+ :eek:
If they offer something in the UK then great, my dealer who I trust will contact me but if we do get something I don't think it will be as special as the GRMN's.
Recording of the live stream (starts just before 10 mins in).
went for a red rally pack. Changes are 0.001% as it appears to be fully JPN stuff but then again it's fun to be part of it!
