GR Yaris World premiere of GR GT3 Concept and fully tuned model of the GR Yaris
For those who have already purchased a GR Yaris, GR parts that allow customers to experience some of the GRMN Yaris performance will be added around Fall 2022 in order to deliver cars “that evolve quickly and can be tailored to individuals” like in motorsports.
Please check the following URL for more information about GRMN Yaris and GR parts
URL: https://toyotagazooracing.com/jp/grmn/yaris/ (Only in Japanese)
Pole Positions are on point but only if you are under 180cm :cautious:
Tbh this is a bit of dream come true for the Germans. Since all of those parts are OEM it will be very easy to get the parts put into the papers.
Especially the Recaros without Airbag will be able to be used as proof that "even Toyota considers the car to be safe enough without" - since this is always a point of discussion when putting in Seats without a Side Airbag.
Very interesting! Wouldn’t necessarily call it “fully tuned”, but some nice bits nonetheless.
Any specs on those wheels? They’re slightly different to the CP BBS.
The update program mentions that there is an engine upgrade for purchase in the pipeline
£54k for the rally package GMRN, compared to £30k for the "standard" GR Yaris in Japan.
Yes was calculating the same, Rally spec is 80% more expensive than RZ High performance a.k.a Cirquit pack car.
In finland that equals ballpark of 80-90k€ with taxes so it will definitely be halo car. Would I trash it in the gravel - I'd prefer ordering RC spec that is 1/3 of that price, add buckets, cage and sequential boxx and would still have 30k left to spend on fuel and travelling.
If they were mean they would have added more finetuned AWD program / differential, just as tease for us mortals. But luckily they use the same.
- Shorter gear ratios - don't see any use - GR's current are fine for my use case.
- Bucket seats - yes would love them, but as using it as a daily it's not plausible feature. Good still that Toyota provides many these bits per factory spec so they're easy to legistlate!
- Mech diffs - prefer torsens
- That tuned look of GRmn - prefer more sleeker look of stock GR.
- Bilsteins - well those would be nice. maybe an upgrade at some point with rally suspension?
Don't know if that means much, but GR was officially THE homologaction spec for WRC, not the GRMN..
Added Torque 20Nm - guessing its from the software as GRMN has better spec clutch they were able to raise the software limiter for torque in ECU map..
Google translate from the JPN GRMN page - understanding they will bring a toyota map for the engine?
Software Update & Personalize GRMN Yaris ― GR Yaris. There is no way to prevent problems that occur one after another in each race, and if you break it, GRMN Yaris also continues to evolve in response to that feedback. As an update program, he is preparing for his update of the engine, which is being trained and strengthened through the race. * The service will be provided for a fee.
Yeah I think the clutch must have been the reason for this change. The engine in the regular GR Yaris should be more than capable of outputting those 20 NM more but the clutch is already a bit of a "weak point" from what I've heard in the regular GR Yaris..
I wonder about how much money and work would it take to have one of those carbon bonnets in body color.
It’s also CFRP so probably wrapped like the roof? Would probably need to be sanded and filled before paint as the finish on the roof panel looked awful under the wrap.
Given the use of car I'd love to have more mid rpm grunt. with Toyota software update, improved few bits and some pixie dust would say 50Nm extra is easy.
I believe that 50 NM are in the realms of what a simple remap and a clutch upgrade can make happen - reliably.
If not then a Downpipe like the HJS ECE one should manage to get you what you wish for.
I'm really hoping for someone to find a way to get a different Tune onto the Stock ECU..
Maybe Toyotas GRMN firmware will be flashable onto the stock GR Yaris ECU :)
