GR Yaris Why are so many Yaris Gr owners changing their wheels ?
Not my car but going for a set of these, JP SL01 in Gun Metal and 8.5 x 18.
I'm going to go for a wheel colour, closest to brake dust. That'll cut down on the maintenance. :)
My sets of wheels were black and white when new and they will eventually end up in the same colour ;)
Why change the wheels? Theyre too expensive to curb, waay to expensive for winter duty and im sure perfect wheels will help when it's time to sell the car.. Those are my reason for having different Sets
wider tires....8x18 is very small at that car. you can easily fit 255 or 265....thats the reason for me. i switch to 9x18 rims. 8x18 with 225 looks like a golf and not a rally car. there´s so much room for bigger tires ;)
Why you notice it with the Yaris more?
Here is my reasoning, proportionally more GR Yaris’s are owned by petrolheads, compared with Golf R, Fiesta ST etc, naturally with petrolheads some like to modify.
Added to this (no offence) most owners seem to be a tad owner than a typical hot hatch owner, and perhaps used to modifying cars.
Also again (just my perception) owners appear to have slightly more disposable income than other makes of car ownership, I’ve come from fiesta STs, and I see more money being spent on the GR
Couple the above with the fear of the cost of replacement wheel (not by all) and you get “man maths” justification for changing wheels 😅😂 even I considered the winter wheel option.
Adding these together and you get the result that proportionally a lot GR Yaris Owners are changing the wheels
@Mintmansam
Definitely the right kind of enthusiasts bought these cars! :p :cool:
I put a deposit down when they were first announced on paper with no pictures. When it said "small AWD Yaris platform with TWO LSD's" - I was SOLD!! :ROFLMAO: ...I knew I had to have one even if it was to experience it for a short time incase life got in the way but so far so good! :love:
Reactions: Els
Which one is it? Superturismo WRC Classic or Evolutione? And do you know the weight? OZ sais 13 kg, cant believe that...
WRC Evoluzione :) I’ll check. It’s a bit heavier from the stock BBS forged wheels but I did’t seem to notice added unsprung weight while driving
For that genuine Rally pedrigree look :cool::love:
These are with the center lock dummies, isn't it?
I was also thinking about them. But I guess I'll take the normal 5 ones. After all it is a road car. But I am not sure.
In rally they got 5s as well. Center lock is more circuit oriented, or am I wrong?
I looked at some classy centrelock wheels with adapters but they were staggered and the offset would have been problematic and the 255/35 vs 225/40 would have raised eyebrows at Toyota. Plus with the adapters the weight was higher than the Oz wheels.
Reactions: Els
Indeed. Did the same. And to be honest, a real center lock is only really necessary when quite often changing the wheels. Like with regularly track days. I am switching wheels two times the year 😅 or when doing some work on the car. So don't really need it. But the looks of a center lock is really good. I like the harmonic centralised look of it. But I think I will stick to some conventional 5 bolts.
Yes. The centerlock is for design only, underneath it has the 5 lugnuts. The Evoluzione is truly designed for the modern day rally cars like the GR Yaris. I also looked at the retro non-Evoluzione version, but the white is more off in relation to the color white of the GRY body. And also, I would say the Evoluzione is more period correct. I thought of taking out the centerlock design which is an option for a cleaner look. :cool:
In my opinion the centre looks fit quite well to a circuit like build with splitters, lowered springs and so on. For the rally look with flaps and beams I'd like to take the more raw 5 lugnuts like the WRC GR Yaris R1 from 2022 season.
Ps: dat intake... 🤤
