GR86 Who said coilovers are needed...
ninjin
Very interesting Japanese Best Motoring video showing a modded gr86.
Most interesting fact is that they highly rated the factory dampers and have kept them with springs from GROW and custom top mounts to give height adjustment.
Well that 20% weight reduction will make life significantly easier on the dampers. Also it's quite a short run...
The revolution gr86 is also used in time attack, which is full laps of circuits.
The dampers don't feel very high quality whn driving. Interesting choice.
Once I've spoken with previous BRZ owner, and he said, that stocks shocks are one of the best available for this car. He said to me, that most of the "pro" drivers, that works on cars, adjust the suspension, after fiddling with aftermarket, returns to OEM as it gives the most consistent results and it's well balanced. Must admit, I was surprised, but above is a clear indication that he wasn't lying so there must be true in the middle đŸ™‚
I've fitted Tein RX1 myself and they do give me more comfort in day to day driving. A reason for going for Tein was the adjustable camber up front via the top mount and camber shim. If I were to do it all again, I think I would just install a set on GROW lowering srings, whiteline camber bolts up front and some adjustable rear lower arms (to enable rear camber adjustment). I haven't gone crazy low with the coilovers, around 25-30mm which is the same as what the GROW springs would have given me.
Going to SPA next week, so will get to see the GR86 on the limit with the RX1.
