The tuning would likely be done with a decat or a high flow cat like the AVO 5 inch one, so those sensors would be deleted. the gen 1 pipe would just be put on for MOT because it has a dense enough cat to pass emmissions tests without the need for a lot of heat firstYou have my blessing to proceed.
Why a gen 1 front pipe? Dont forget our front pipes have a couple of pressure sensor pipes which the Gen 1's don't have.
Ok, I just didnt know if the two pressure sensor pipes were deletable or not. I am sure they can be mapped out so to speak, but if they cna just be removed or blocked off then it means we can use the HKS midpipe which has a resinator in it. Not read anything concrete about them yet.The tuning would likely be done with a decat or a high flow cat like the AVO 5 inch one, so those sensors would be deleted. the gen 1 pipe would just be put on for MOT because it has a dense enough cat to pass emmissions tests without the need for a lot of heat first
TD recommend installing their straight-pipe, so I guess they have a workaroundOk, I just didnt know if the two pressure sensor pipes were deletable or not. I am sure they can be mapped out so to speak, but if they cna just be removed or blocked off then it means we can use the HKS midpipe which has a resinator in it. Not read anything concrete about them yet.
