leosayer
I thought I'd share a little table I made for myself based on reading the manual and this link.
Hopefully it's of use and correct. I'm happy to update with corrections and suggestions.
| Name | How to activate | Display | Warning lights | Vehicle Stability Control (VSC) | Traction Control (TRC) | Brake LSD |
| Default | Start the engine or TRACK button short press or VSC OFF button short press | Normal | None | On | On | On |
| TRC off | VSC OFF button short press | Normal | TRC off | On | Off until speed exceeds 31mph | On |
| Track mode | TRACK button long press | Track | VSC off | On - Track mode | On - Track mode | On - Track mode |
| VSC Off | VSC OFF button long press | Track | VSC off TRC off | Off | Off | Off (Manual) Track mode (Auto) |
| Name: VSC / Vehicle Stability Control Trigger: Understeer or oversteer detected Action: Brakes individual wheels and if necessary, reduces throttle Result: Corrects the car's course |
| Name: TRC / Traction Control Trigger: Both wheels spinning under throttle Action: Reduces throttle Result: Improves traction under throttle by stopping both wheels from spinning |
| Name: Brake LSD (this is not the mechanical Torsen Limited Slip Differential) Trigger: Single wheel spinning under throttle Action: Brakes the spinning wheel Result: Improves traction under throttle by sending torque to the other wheel thereby activating the Torsen LSD |
