Here is another option:
How do find out the current sensor ID's - can it be done without having to remove tyres to get an eyeball on the existing sensors ?
The ID's can be read using a programming gadget. No need to remove the tyres. A good tyre fitter should have a programmer.How do find out the current sensor ID's - can it be done without having to remove tyres to get an eyeball on the existing sensors ?
In case anyone has the same, I replaced the valve (+ related parts) with this part number direct from Toyota, cost me something like £17. Then got a garage to switch my TPMS module over to it (which was all fine), and all good now.I'm pretty sure one of my oem valves has failed, losing pressure and when putting the gauge on it, the dial slowly climbs to the indicated pressure. Usually it'll fly up the dial with a 'shoop' noise as I'm sure you're all used to.
Do I get a single tpms valve from Toyota? Or can someone link to an aftermarket one they've got to work with the cars ecu/readout?
Not sure I need a set of 4.
Thoughts welcome
The sensor and coder tool must be from the same brand. Are you looking for a set of sensors or just the coding?Is there anybody near Nottingham or the surrounding areas with one of these Autel readers and able to code to my car? I would travel to you of course. Just picked up some GT86 wheels for winter and about to get tyres mounted to them in the next 2 weeks. While it is still cheaper to buy a reader and code myself, for a tool that will be used probably twice ever I'd rather pay somebody a bit of money to do it for me. My local tyre fitter were going to charge £75 per wheel for the sensor and coding. Toyota were £260 for the sensors and god knows what for labour on top for a 2 minute task. They would probably overwrite the main sensors too![]()
I am looking for both, I just see Autel pop up regularly. If somebody has a certain brand that works and can point me to buy the correct corresponding sensors I will get them.The sensor and coder tool must be from the same brand. Are you looking for a set of sensors or just the coding?
If you want to pop over to mine one day during the 'holidays' I'll give it a go with my Autel handset. Takes no more than 10 minutes or so. Routine is: Scan each wheel on the car in sequence. Connect handset to OBD port. Push Sensor data up to ECU as 'current set'. Switch off car. Drive off. Sensors are usually detected immediately with this method and it doesn't require 10+ minute drive.Anyone in central Scotland able to code two Toyota OEM sensors to my car?
Fee payable work of course…
Pretty sure that you don't even need to do that; if you swap a wheel, the car is able to determine which position the sensor has moved to. Not sure how (some sort of witchcraft, presumably), but good to know when rotating tyres.One profile and as long as you put them on in the correct position they all correspond correctly in the screen.
I dunno what made it work but the pop up and the big warning light have gone away.Pretty sure mine are set lower than that. Not sure what exactly, but I don't remember it being an issue. I just used the reset button and that was that, and haven't seen the warning since, even on cold mornings.
You may be right but I made sure to put them in the corresponding positions anyway. When I put the normal wheels back on in March the fronts and rear will be switched for the first time so I may test then to see if the fronts and rears switch by purposely under/over inflating one tyre. With the huge amount of snow meant to be coming down tonight the tyres are very welcome!Pretty sure that you don't even need to do that; if you swap a wheel, the car is able to determine which position the sensor has moved to. Not sure how (some sort of witchcraft, presumably), but good to know when rotating tyres.
