GR86 TPMS Sensor Relearn
CoopJ10
Burgess Hill, West Sussex
Hi,
I have just purchased a silver '23' plate GR86.
The car is great I am really impressed and pleased with it.
One issue I have is that the TPMS system is not showing any of the tyre pressures on the dash.
On power up the tyre pressure warning light is illuminating and flashes continuously for about 1 minute then becomes solid.
Pressing the TPMS reset switch 3 times in the glove box does not do anything.
When purchasing the car I noticed the LH rear alloy had a slight chip. I got the dealer to swap the wheel out from another GR86 he had in stock.
This I believe has caused the issue I have been having and a 'relearn' of all TPMS sensors has to be performed in order for the system to function correctly.
I understanded a Autel TS501 relearn tool can be used to achieve this, however at £200 I am a bit loathe to purchase one.
I was wondering whether anyone can recommend a suitable Garage in West Sussex who could perform this task for me ?
Or any one local to me (I live in Burgess Hill, West Sussex) who has a Autel or similar tool who could help me ?
Thank you
Simon
Congratulations on the purchase.
As an alternative you could pick up an OBD cable and TechStream software and that would allow you access to all the customisations etc.
They're pretty cheap (<£20).
Have a look at this thread.
If you bought it from a Toyota dealer, I would get them to deal with it, if you can. If they swapped a wheel, then really they should have made sure the sensors were updated or swapped as well.
If not, then I guess any tyre fitter might be able to check and update the codes for you - TPMS sensors are ubiqitious these days, so I think most will have the tools to sort them.
Also worth emntioning that if youre in Burgess HIll, you're not too far from Abbey Motorsport (Oxted, Surrey), who are one of the best and most reputable garages when it comes to these cars. Worth giving them a shout, if not for this, then for anything else you might need for the car...servicing, modding, anything really.
The car came from an independent dealer. Thankyou for recommending Abbey Motorsport that's good to know.
Thankyou, i have had the car for 2 weeks now and am really enjoying every drive !
Thank you for pointing me to the thread I will have a read
Hi,
Thank you
Simon
Pressing the TPMS reset button 3 times doesn't reset the system. You need to hold the button down for several seconds. Take a look below for full process. I hope it is useful to you.
Thank you for the advice but issue is still there, I believe it is just a case of registering the sensor on the exchanged wheel and the problem will be solved. I will contact local tyre companies to see if they can do this.
The TPMS sensors need to be active before you can perform the relearn - this is the part that the Autel tool (or similar device) does. Any competent tyre shop should be able to do this for you - it takes 30 seconds per wheel. Then you can follow the relearn process.
Was the sensor on the replacement wheel coded to the car?
