tonic
- Aug 31, 2023
- 217
- 702
As many of you may know, Toyota uses the Super Taikyu (Super Endurance) series as a platform for developing their GR Yaris and GR Corolla. I thought it would be interesting to dig into some of the issues they are having on the track and the solutions they've implemented to address them.
Here are a few photos from their 2024 GR Yaris development efforts. The car in the photos is equipped with a DAT8 gearbox and the cooling setup is nothing short of extreme
I tried to piece together what each component might be doing, but this is just an educated guess. Feel free to share your thoughts if you spot anything interesting.
My Guess:
1 - Transfer case cooling. Seems to be connected to the RH HPI oil pump. Why is it located behind the coolant sub-radiator? My theory is that they might not be using temperature-based oil pump control, so the hot air ensures the transfer box oil doesn’t get overcooled. Or perhaps there simply wasn’t another suitable location for it.
2 - Additional engine coolant radiator. Judging by the hose diameter, this one seems fairly obvious.
3 (3a + 3b) - These two appear to run in tandem and might be connected to the LH HPI oil pump. My best guess is they’re used for cooling the automatic gearbox.
4 & 5 - Engine oil and fuel cooling? I’m unsure about these. Interestingly, No. 4 uses general hose clamps. Could that mean it operates under low pressure or isn’t as critical? Maybe something like driver seat cooling?
6 - Rear diff cooling.
You might also notice the seafoam green hose, which seems to be used for cooling some sensors. My guess it’s MAP sensor, possibly due to the placement of the 3b core it gets overheated.
I know there are more questions than answers here, but it’s fascinating to see how much effort goes into keeping this engine and gearbox functional during an endurance race.
Hopefully, you’ll find it interesting as well
My Guess:
