Yes. The piston explodes and conrod flops around and punches holes in the block and usually takes out the balance shaft in the processView attachment 37769
I’ve seen many cases of balance shaft failure. Does anyone know what usually causes this problem? Sorry if my English is not very good.
我們國家已經出現過好幾起這樣的案例了,但是我在論壇上沒看到有人提到。我沒看過有案例啊?
From the multiple cases I've seen, there wasn't a piston explosion or holes punched through the block. Most of the damage seems to be lower-end failures or cracks at the bottom — but maybe there are other cases I haven't seen yetYes. The piston explodes and conrod flops around and punches holes in the block and usually takes out the balance shaft in the process![]()
Well that image of the balance shaft looks like colleterial damage. What went through the gear teeth to start with? What damage the counterweight and what ever it was punched a hole through the timing case.
