shoeihsieh
After the rain cover is installed on the engine cover with a vent, the heat dissipation effect is not as expected, and it is meaningless to replace the engine cover. When it rains, the best thing to do is block the vents with fiberboard so the rain doesn't get in (unless you're racing for competitive purposes and don't care about dirt). Therefore, all hoods with ventilation holes should pay attention to the location of the ventilation holes when it rains, where the rain will flow, and whether it will affect the electronic components inside the engine. The vent on the hood of the engine meets rain, and the water flows to the intake manifold, so far no electronics have been affected after I drove in a period of heavy rain. The fact that any electronic component in the car is waterproof to some extent is nothing to worry about, after all, you are not soaking the car in water.
In addition, even if his opening is not as big as GRMN, but I can tell you for sure, this does have a certain heat dissipation effect, as long as you drive at a certain speed, hot air can be smoothly exported, especially when it rains, you can clearly see the windshield there is hot gas generation, which is not a phenomenon under the OEM hood. And the opening is too large, the stability of the vehicle is relatively serious, so it is best to choose the product that has been tested by the wind tunnel will be safer.
