So I used bronze spherical bushings, they didn't sit put in the holder so fixed them using Sugru, which is a mouldable glue/rubber that retains some flex and can take - 40°C to 180°C. Since I only bond from the outside, it should be reversible by simply cutting the glue off.
Just one large washer on the outside so it can't fall off in case the Sugru ever fails to secure the bushings (on inside the arm is there) and then the OE pin could be used.
Left-right:
Fore-aft on my Foresight shortshift:
Left-right:
