jerseyjackson
- Apr 24, 2023
- 5
- 13
Havent seen such before, thought all AN connectors used crush washers?
This connector is ridiculous. Even after you tighten it onto the oil sandwich plate, you can still rotate the connector by hand, so I don't think it can seal properly at all.
In the end, my friend and I both switched to this type of connector, and the problem was solved.
Actually all the other HEL components are of good quality; it's just that connector defective.
