GR86 Re-activate TPMS?
BenjiSayers
Absorbed member
Durham
Hey all,
Had aftermarket wheels with no TPMS on them for just under a year. Just re-fitted my stock wheels but I can't work out how to get the car to read the pressures.
I've driven it for like half hour and nothing got picked up, the only difference is now where the TPMS light would always flash it's now on solid. Is there a reset or something I need to do?
TIA
yeah, you need a TPMS tool (any brand) to re-activate it. Had the issue on mine.
Just re-fitted my stock wheels but I can't work out how to get the car to read the pressures.…. Is there a reset or something I need to do?
If they are the same wheels and TPMS as originally fitted, their data will still be stored in the ECU, so you should not need a specialist tool and just have to go through the reset process as detailed in the user manual. It’s also in the TPMS thread.
The button for resetting the system is in the glovebox (rhs). Below extract From Google AI:
I tried this and it did not work, multiple times. In the end re-activating the TPMS worked straight away.
Thanks both, I had to take it to kwik fit and they used the tool. I did actually see the image above and had given that a go but no good. Only cost £39 to get them re-linked which is better than having my pants pulled down like Toyota would have done.
