GR Yaris Quest for 400bhp - advice needed
Lewis82
Hi,
New member here - please be kind lol
I’m looking for some advice on getting to 400bhp please. Will the following mods get me close:
  • MST V2 closed induction system
  • mongoose exhaust system (GPF still fitted)
  • Airtec stage 1 intercooler
  • Airtec stage 1 oil cooler
  • Prohose kit
  • Kelford A cams
  • Kelford springs
  • Ecutek software
Cheers
I think you'll be around 350 with them mods. I'm not sure 400 is possible on standard turbo, I think 380 is about the limit.
And if you're upgrading the turbo then there's no point restricting yourself to 400! 😈
If you're doing this then you should probably add Denstoj rocker retainers to your list, seems the head is open. And if you're taking the head off then may as well do HKS gasket and Supertech valves with bronze guides.
You might want to add uprated inlet manifold and HJS downpipe before messing with the above though.
Isn't stiffer valve springs pretty much mandatory as well on that kind of power?
Appreciated, that seems doable and just within budget. Will the downpipe cause problems with the MOT??
I’m knocking on the door of 400 with a standard turbo (and air filter!), and a lot of midrange torque. Reckon I could maybe get to 400 with an inlet manifold - I went for syvecs which is obviously a big cost, but I think gives more torque/power and is IMO worth it for the peace of mind of full engine control vs reverse engineering tables. It’s basically required for the bigger boys’ world of forged engines, sequential gearboxes, e85 and ginormous turbos if you want to go there one day. But mapping/dyno time is not cheap.
I think any tuner will suggest you decide on a target and stick to it - maxing out standard turbo and ecu is a reasonable thing to aim for.
Doing things gradually can also work, but doing engine work every five minutes will add up in labour quickly. There are big steps in cost for standalone ecu, full frame turbo and forged internals.
“While you’re in there” is a powerful argument depending on your longer term plans, but fancy valves are perhaps more of a finishing touch for a mega high end build IMO, think there are lots of big power/turbo cars without them - but I have no first hand experience. I went for an uprated gasket and head studs when doing cams and springs, maybe overkill but basically insurance so 🤷‍♂️
I would chat to a few garages about short/long term plans, budget and options before going shopping. And having a garage not a million miles away is always useful.
I should also add I currently have a broken (uprated) clutch and a slightly dicky gearbox, so don’t spend your entire budget on shiny bits depending on what power/torque you aim for 😀
Tuning guides on Whifbitz website and motive YouTube are worth a look.
Cheers for the time bud, Whifbitz is my garage of choice. They’ve given me a quote for some of the work, but with the distance I’m waiting another month to fund everything in one trip - I have the intake & exhaust currently , running on a CP map. I’m not even sure where I’ve got “400” from, but I’m not looking to forge the engine or push for records, and I use this as my daily. Once the work above is done, I might (and it’s a big might) go for another turbo and inlet manifold.
There's a shop here in Sydney, Tunehouse, that is highly regarded so I looked up what they can do with the GRY without changing the turbo - this isn't based off specific advice, though I assume they've worked on a number of Yarises:
Tunehouse GRY breakdown here
  • THR Spec Port Injectors 1100cc
  • THR Spec Ethanol Content Sensor
  • THR Spec Flex Fuel Configuration
  • THR Spec Front Mounted Intercooler
  • Motec M1 ECU With Wideband Lambda & Logging
  • THR Spec Down Pipe With High Flow Cat
  • THR Spec Cat Back Exhaust
  • C-Tech Carbon Fibre Intake
  • THR Custom Tune
  • Dyno Optimised Outcome
The claim is 100kw and 200nM torque - which, if anything, takes it past 400hp. Thoughts?
how is the MST V2 closed induction system for you??
Ive got an HKS Turbo Muffler exhaust and looking to go stage 1 done by phantom tuning after fitting an air intake.
Also, what HP do you think this will make overall after all this?
Thank you!
Hey, not sure about any increase in power, it felt like there was a difference and it sounds great!!!
If I'm being honest, I regret not going for the Eventuri though as all the big builds seem to be running them. I have a lot of work planned for the 24th of this month so I will have some data before and after the work. I let you know how I get on
So the MST gave me 8bhp over stock on a dyno
Thank you!
Hi, it gave me 8bhp over stock on a dyno
A genuine 400 hp at the crank on the GR correlates to 340-350 wheel. You won't get near that without a hybrid turbo or high concentrations of ethanol.
