mackie
I'm hoping someone can give me some guidance as to what to try next ("take it to a proper garage" is acceptable
I installed the Reyland AP brake kit over the weekend but left the job of bleeding until yesterday when I had some free time. I used a pressure bleeder pumped up to 1 bar but did it "dry" (i.e. no fluid in the pressure bleeder reservior, just keeping the master cylinder reserviour topped up as neccessary) and pretty much did a full flush starting at the rear left and working towards the driver side front.
Engine off the pedal felt pretty firm but does sink slighly over time with lots of effort. With the engine running and with servo assistance the pedal sinks to the floor after a few seconds of firm pressure on the pedal. This lead me to bleed them again, no visible bubbles. I checked for leaks from the unions and bleed nipples and nothing evident.
At no point did I touch the brake pedal when bleeding (possibly my mistake?). There's a *chance* the fluid got too low at one point but I was keeping an eye on it and being careful. From a bit of research is sounds like I might have accidentally got air into a subborn place in the MC which sounds like a job I don't want to tackle.
I'm thinking it's worth trying a "pump the pedal" bleed before anything else as intuitively this should force any air inside the cylinder down the lines.
Any advice appreciated.
