GR86 Pedal goes to floor after bleeding brakes (twice)
mackie
Hertfordshire
I'm hoping someone can give me some guidance as to what to try next ("take it to a proper garage" is acceptable :P).
I installed the Reyland AP brake kit over the weekend but left the job of bleeding until yesterday when I had some free time. I used a pressure bleeder pumped up to 1 bar but did it "dry" (i.e. no fluid in the pressure bleeder reservior, just keeping the master cylinder reserviour topped up as neccessary) and pretty much did a full flush starting at the rear left and working towards the driver side front.
Engine off the pedal felt pretty firm but does sink slighly over time with lots of effort. With the engine running and with servo assistance the pedal sinks to the floor after a few seconds of firm pressure on the pedal. This lead me to bleed them again, no visible bubbles. I checked for leaks from the unions and bleed nipples and nothing evident.
At no point did I touch the brake pedal when bleeding (possibly my mistake?). There's a *chance* the fluid got too low at one point but I was keeping an eye on it and being careful. From a bit of research is sounds like I might have accidentally got air into a subborn place in the MC which sounds like a job I don't want to tackle.
I'm thinking it's worth trying a "pump the pedal" bleed before anything else as intuitively this should force any air inside the cylinder down the lines.
Any advice appreciated.
I guess I'm on my own then 😭
I've bought a non-return valve conventional bleeding kit so I'm going to try the old fashioned way tomorrow and if that doesn't work take it to my local garage I think.
Good luck. Fingers crossed the old fashioned way will work.
Don't you mean "take it past my local garage?"
Anyway, not an expert, but isn't the idea to keep the pressure bleeder full so that it keeps the reservoir topped up? Perhaps by taking it off to top up the reservoir yourself, you introduced a pressure loss and pulled air back into the system?
Where’s the bleed nipple on the new calipers?
Elise twin pots are notorious for being a shit to bleed - the best way is to remove the caliper and invert it, so the bleed nipple is at the top.
There are 2 bleed nipples on the top of each, one for each side. I let a lot of fluid run through but who knows 🤷‍♂.
Does it repeatedly go to the floor?
I've done the brake lines only once, many years ago, but remember bleeding them and then reversing off the drive, and the pedal went to the floor. I believe it's because when you bleed them the pads don't move so once you've finished, the pads need moving back on to the discs and might need a push or 2 of the pedal
Yeah, doesn’t matter how many times I pump, it’ll go to the floor eventually. I suspect it needs an MC bleed but will see how the regular pedal pumping bleed goes once the kit arrives.
Ah ok, different thing then. This was down to the floor and a little bit on the 2nd pump after a mild panic as the car rolls towards the road with no brakes 😂
I started typing a reply, but figured that, "stick a bit of fuel pipe on the nipple into a bottle of lucozade and keep topping up the reservoir and pumping th brakes until you run out of brake fluid" wasn't good advice, although it has served me well in the past 😂
Re-bled everything (twice) with the new kit and it now seems fine. There were bubbles the first time round so I suspect it was down to brand new bone dry calipers being a bit stubborn to bleed.
Gentle bedding in today.
