If doing audio upgrades in 2025 . Which is the most popular, easy to install, I’ve looked at both Audison and Focal as options but would welcome advice/result etc. and are you better off getting an expert to fit?
Thanks
Thanks
I fitted the front ISTOY165 Focals (mid and tweeter) and it improved the sound significantly over the stock JBL speakers. I enjoy listening to music and I couldn't live with the standard system. One of the bolt holes in the mids needs slightly elongating to fit correctly (just use a drill).
It was easy to do, just takes time. Removing the A pillar trim (airbag connector) is fiddly the first time, but there are plenty of guides online. Removing the door cards is simple.
Example of a front door install from 4:40 here:
The front Focals were a big improvement over the stock JBL fronts.No vibration-insulating mats in the doors/on the floors? GR is generally a noisy car with limited potential of improving. Not voting for the stock music cause it's just about the radio, but how much of their capabilities Focals do with stock bear metal almost everywhere?
I used the crossovers as they came on the Focal fronts and tweeters, they sound fine. I left the stock mid connected in place.So the ISTOY165 kit fits fine in place of the JBL's- apart from the woofer (door speaker) requiring the hole elongated? Did you leave the built in crossovers on the Focal speakers in place- or bypass them? My understanding is the JBL system uses active crossovers so the crossovers on the ISTOY165 shouldn't be required? And you left the stock JBL mid range in the dash?
It's been something I've considered doing for a while for- the same reasons. It just doesn't sound right stock.
Have you left the ANC functioning too- does it still work?
(I've circled the crossover components below.)
Thanks for the info.I used the crossovers as they came on the Focal fronts and tweeters, they sound fine. I left the stock mid connected in place.
I have ANC (and ESE) turned off, as I couldn't hear the tyres properly when near the edge of grip on the track...
