GR Yaris My gas lifters
Amanda
Devoted member
Hi after the Collins meet and seeing Phils car with gas lifters I wanted a pair , so I ordered some from Fensport , only we had a slight problem they don’t fit with the gazoo racing strut brace 🤦‍♀️ So I contacted Fensport who kindly refunded me and told me to keep the lifters for all the trouble it had caused fitting them , well I wasn’t been beaten it’s taken me over two weeks to get them to fit by redesigning the brackets a couple of times and using different ones for the hinge side, I love the way they now look 😎
Well done for sticking at it!
That's how the kits should be sold.
That looks brilliant. 😎👍
Thanks everyone here’s a pic of the original fitment that was catching my strut brace
Indeed, looks very factory.
Would also be interested if you fancy knocking out a few sets. Think many would be, tbh!
One thing though, how is the bonnet closing? Can you still drop/slam it closed, or does it need a push to latch?
With aluminium I'm always wary of it needing a push and buckling the thing. Not so much for me as it's me car, but in the garage etc. 😬
You drop it as normal , and you have to push it up aswel it’s only the last few inch it goes up itself and holds if that makes sence , Ive seen other ones flying up from quite low which worries me , here’s a pic for an example it’s holding there at that angle but not flying up
I will be telling Toyota when they service it to pull it from the pin thing inside aswell that locks it shut , rather than grabbing the actual bonnet to pull down
GReat job ! I would be interested too... If it's really plug & play.
I like the idea that it lifts the bonnet up higher than with the OEM "stick".
