So I've had the car for over a year now. It has been a journey. however the gear shifts were quite notchy and had occasional lurching forwards under acceleration. I recently had a big service done, gearbox oil, clutch fluid and so on. It has made a noticeable difference. Still there is something there not quite right.
Im now wondering if replacing the stock engine mounts would help with gears and engine feel. I went in looking to see what just engine mounts would cost. To see there is a right one but no left. Left is transmission mount? Ok cool. Then it seems there is a rear engine mount too. Some peope talk about torque mount also but seems its not readily available here.
What mounts should i be replacing?
Is it worth doing these 3 only? (Rear,right engine and transmission mount)
Or should I try source a torque mount from some UK website.
Figure I dont need race versions as this is for road use?
Hardrace is the only brand available, assume they aren't bad?
This is for a 2020 model
Any tips or advice appreciated, I am no mechanic or much of a hands on enthusiast.
