GR Yaris (Gen 2) MK2 - lowering the windows before opening the doors
Fred
Absorbed member
May 17, 2024
83
87
18
Southern Germany
I find it annoying that there is a slight delay in lowering the windows before the doors are opened.
If you don't deliberately open the doors slowly, the windows stick briefly to the door rubber at the upper rear corners.
I don't know this “bug” from other cars with frameless windows. There the windows lower quickly enough.
The “lowering impulse” on the GRY should simply come a little earlier.
Do you have the same phenomenon and, if so, does it bother you?
Maybe this can be adjusted?
Not so much you could do i say. You have a sensor wich say if the door is open or not. And that sits under the hook in the door sill. But i think you can not do anything to that so the windows go because they go down as quick the car detectes the door is open.
I have pressed the sensor to make the car stop pling on me when parked and have the door open when you turn the car of.
Reactions: GottGry
I have used a bit of tallow, or Ballistol in the “rubber corner”. This helps to let the windows snatch a bit less. Additionally I just open the doors sloooowly which also is good against my ADHS 🤪
Reactions: sha256
I don't think it's anything to worry about. The lowering is there less for the opening and more in anticipation of the eventual closing. It opens fine before they lower, but closing it with them all the way up would likely be a pain.
Door open
Turn off car
Push the black thing on the door sill that's the door opening sensor then it's stops bing ping
Can you confirm that this is normal? It's a bit scary in the long run.
