Fred
Absorbed member
I find it annoying that there is a slight delay in lowering the windows before the doors are opened.
If you don't deliberately open the doors slowly, the windows stick briefly to the door rubber at the upper rear corners.
I don't know this “bug” from other cars with frameless windows. There the windows lower quickly enough.
The “lowering impulse” on the GRY should simply come a little earlier.
Do you have the same phenomenon and, if so, does it bother you?
Maybe this can be adjusted?
