sixtentouge
- Aug 28, 2023
- 206
- 825
Has anyone who’s suffered from this issue changed the MAF sensor yet? I wonder if the P/N has been superseded or if there is a variance in part numbers between manufacture years etc? I maybe barking up the wrong tree but surely it’s just a case of software & sensor outputs?
It's not a MAF sensor issue. It's a re-map issue. That's why the 20 minute "reset" restores everything. You go in and start monkeying with boost targets and what not, only there's a lot of modeling going on in the background. Turbine speed, exhaust temperature, and even EMAP are modeled in this ECU. So it doesn't like sensor input that it's seeing from the increased boost. "If-Then" no longer equals "Goto," and starts doing strange things. But because other things that have been changed, the things it tries to do have strange effects on other things and it cascades into a place that's way outside the original operating parameters. The ECU has learned its way into a corner, so to speak.
So you reset the ECU and all of the learned data is reset back to where it all works again. But it'll eventually learn back to not working again. I've seen this sooooo many times here in Japan. Do re-maps give people more power? Sure. But the hope is that the quality of the re-map, or the place the outputs end up doesn't end up putting a piston in the oil pan.
