I’m guessing you think it is a stability program cutting in ?You haven’t mentioned if using expert or expert+. If I was a betting man going into expert or expert+ the problem might disappear.
Not sure if it’s stability related but when I first got the car (nearly 3 years ago now!) I found some days doing the traffic light Grand Prix even little shopping cars could out run me as it bogged down even when not expecting it. Switching to expert I’ve found it just takes off consistently.I’m guessing you think it is a stability program cutting in ?
I would guess TC related would be visible as throttle pull. if throttle is not pulled, ecu is backing boost of some other way (that is unknown).
This was a perfectly cold night though and it’s super inconsistent. I’d understand if this happened every pull but the matter of the fact is it doesn’t…that's normal, car has hardly 1bar boost at redline in certain conditions.
You’re spot on with the first bit. That’s all they did, took data off ecu, charged me and said they couldn’t find anything wrong with it. My ECU never seemed to have this kind of issue before though? As I said this issue ONLY started out of nowhere about 3-4 weeks agoGood luck buh' - You will be the first
My prediction. They will keep taking your car, doing their 40km'h single runs and charging you 200 kangaroos every time you go there and then telling you how there is nothing wrong with it
Andrew from Motiv replied to my query himself and said that his has never seen an ECU that has been this inconsistent before
For the record I have not tuned for Ethanol either. The stock ECU handles my mix just fine
I would love to go the route of ECUTEK sometime, but I am in Brisbane and will be a downright lab rat, which I am not keen on
Biggest increase with Ethanol that I have observed is the down low torque - Knock Feedback value is back up to 24-26 btw
Not something I’ve tried, will go out and test more in the coming nights as I have got a few 8-9 degree Celsius nightsYou haven’t mentioned if using expert or expert+. If I was a betting man going into expert or expert+ the problem might disappear.
I tried E20 and then E30. I would not go anywhere north of E30. The start on E30 is sus enoughYou’re spot on with the first bit. That’s all they did, took data off ecu, charged me and said they couldn’t find anything wrong with it. My ECU never seemed to have this kind of issue before though? As I said this issue ONLY started out of nowhere about 3-4 weeks ago
What’s your mix? E30 or E50 blend?
Is that safe within the normal knock range?
Ahh yup awesome, do you use any tools to measure out your E blend? Or do I just keep driving until the dash shows 0km range left?I tried E20 and then E30. I would not go anywhere north of E30. The start on E30 is sus enough
So 17L of E85 and the rest is RON98
What do you mean safe within normal knock range? The whole point of E## is to push higher RON values to reduce knock probabilities. The issue stems from the fact that for me, the knock feedback value is sticky. When you fill up with this new blend, you force the ECU to re-learn the values. This is why many suspect "bad fuel", (which in fairness could be)
Funnily enough, the first time I did so, my value went from 20 to 24ish under normal driving conditions, but at WOT it has an other feedback value that is seperate from the first. It kept the same value as before (21). Took a while for the ECU to realise what it was doing. Because of the discrepancy, at partial throttle, my acceleration was miles ahead of WOT
(Also because my car is a daily I am okay with having high ethanol figures in the tank, if I were to store the car as a collectable (what a waste!) I would stay as far away from Ethanol as possible)
MathAhh yup awesome, do you use any tools to measure out your E blend? Or do I just keep driving until the dash shows 0km range left?
I’ve confirmed with someone from Toyota that the dash lights comes on at 20-30km range (forgot which one), but when it shows 0km range the cars still able to do another 100km - apparently.
Edit: our tanks are 50L right? I usually always fill up at my last bar, which to fill up to full is anywhere from 30-35L
This is precisely what I think the issue is and why I think changing/modifying the engine management is the only way to properly resolve it. Development of the software, which was new and unique to the GRY, hasn't sufficiently accounted for the range in variance of hardware.Or, the ECU programming is not capable to deal with the real world variations in how the hardware responds - that, or said harfware has too large variations. Something like that.
it's certainly the way Toyota released the car but I think the software needed further refinement imoIt is normal ecu is not always boosting 100% - part of normal function not a failure.
imo the inconsistency is more algorithmic than any specific piece of hardware or condition like intercooler and temperature respectively. It happens when it's cold too.How much would an aftermarket intercooler help with this? In my i30N it definitely made it more consistent on hotter days.
