Sorry, this is nonsense.
A waisted bolt, which adjustable camber bolts are an example of, will actually have
better clamping reliability than a conventional bolt for a given torque as the bolt stretch will be greater due to the reduced cross section of the waisted part.
Torque is only a way of applying load to the bolt and needs to overcome the friction of the thread and seating face, and that's it. You apply the recommended torque regardless.
As both of these friction factors are the same in this application whether the bolt is conventional or waisted, the absolute load applied will be the same but the additional elastic stretch of the waisted bolt will mean that it is better able to withstand loss of tension due to vibration, heat cycling etc.
The difference on such a short bolt under low load will be marginal, but it is undeniable.
Source: Worked in industrial bolting for many years
