Torsen diffs spin a wheel if it loses contact with the ground - this was happening to me on track, I think at the front. Changed ARB at both ends to try not to upset the balance, it stopped the wheel lifting. As you say, I wouldn’t use them if I could avoid it, as you are basically making your suspension less independent, and a stiffer bar reduces grip at that end of the car - so you might use them to change under/oversteer balance. In my case, they were cheaper than fitting a plated diff
Generally people like them as the car corners flatter, so it feels faster - but mostly isn’t. One possible exception is stock lower control arms losing camber in bump, and stiffer bars reduce this. But better to use Wiborg/verkline arms instead I think.
I think I had the whiteline originally, which fouled the brake ducts i was using. I think I changed to hardrace at some point to be able to use the ducts again.
