GR86 Hood/Bonnet Gas Struts
Sonic
Zookeeper
Staff member
Dunfermline
Anybody here fitted Gas Struts to their GR86 bonnet? Although I like the look of them, my engineering brain has me feeling a bit wary, especially when the bonnet is closed when there may be a permanent 'shearing force' acting on the bonnet fixing bracket bolts in a direction to which they were not designed to resist. Any positive/negative feedback from the floor?
I have. AliExpress special.
Easy to fit. Care needed to avoid dropping the nuts and bolts into the void between the inner and outer wing!
I have not noticed any issues. They are not mega powerful, I need to lift the bonnet the first 12 or so inches and after that the gas struts continue the lift. It goes up pretty gently.
Cheers. I've ordered a set and will give them a go.
I've a set of those . Needs lifting a couple of inches before it start taking the bonnets weight.
Received my Gas Struts from AliExpress today. It took some effort to break the ‘stiction’ but they seem okay now. One of the foam pads has a compression dent too (from transit I think) although it won’t matter much as I intend to use 3m protection tape between the surfaces, just to protect the paint a bit more.
Research shows tightening torque for bonnet securing nuts to be 25Nm for those of us fastidious types. :geek:
I had some on my GT86, which was one of the first mods I did to that car. Think I might order these too . . .
I use the mentioned Aliexpress set since last summer and have no problems with it. Given the pretty low price I am very happy with it. To get an idea of of its lifting power. Video starts where the struts are able lift up the hood by themself.
I've had exactly the same delivered last week - just need to find a spare couple of hours to install them
The sun was actually visible today, so after a quick 10 mile bike ride this morning, I set to and fitted these struts. Access to the nuts on the body could be better and a ratcheting spanner of the right size (12mm) would have made things easier. All done now though.
Just a heads up, I stumbled across this thread as I've been thinking about fitting struts, but I remember how I had them on my GT and thought they were a bit of an extravagant purchase for what they achieved....but I had a look at those AliExpress ones, and they are currently reduced to £22.99. Assuming you guys are still using them no problems, can't really afford not to.
… I had a look at those AliExpress ones, and they are currently reduced to £22.99. Assuming you guys are still using them no problems, can't really afford not to.
Still working fine here. They are quite temperature sensitive though; opening slower on cold days and quicker on hot days, which is to be expected given expansion dynamics. How long they last is yet to be determined, but when you can buy 3 or 4 sets from AliExpress for the price of a single ‘branded’ set in the UK, that helped in my decision - especially as I’m naturally tight fisted... 😉
Same here. Still working with no issues.
Have noticed the bonnet itself can swell when hot as you see the lines change slightly. But when it cools it goes back to normal.
Mine have been on since day one, so coming up to 2yrs. No issues. AliExpress too.
Fitted mine today. Have to say, you can see that the price saving must have been in the quality control. One of the struts had a crack in the plastic shroud, and the other squirted a load of white lithium grease out of the ball joint as it was pressed onto the bracket...none of the others had any grease at all!
Might message the seller, but I'm not too worried as once on, they work fine, and I'm not bothered about a cosmetic crack I'll never see. To be honest, if they asked me to send the whole lot back for a replacement, it would be more effort than it's worth. Getting the brackets fitted to the lower hinge was a pain as there's very little clearance around the bolt holding it to the wing. Even with a ratchet spanner it took me ages to loosen it, one click at a time.
I would deffo get in touch with the seller via AliExpress. I've complained about parts with less obvious defects and received a full refund, plus if it's a 'first' return, AliExpress will waiver any return shipping cost (they may even say to ditch the defective unit). It's certainly worth trying if you were not happy with the item. If nothing else it will flag up the seller as sh** and you can put some negative feedback to help other shoppers.
AliExpress vendors are so weird.
I messaged them saying the strut had a crack in the plastic. Sent the pictures.
They responded "So it's broken, right?"
"Yes"
Nothing for a day or so. Then they send me a link, which appears to be a one off custom link for a strut, costing £10, and a voucher code for £10, and say to order that and they will send it.
Somehow, in the process of ordering (I guess due to exchange rates, it actually ended up costing £1.89, but it looks like they'll just send me a new strut. Whatever, still cheap overall. But why not just send the replacement, rather than go to the effort of giving me a link to a new one, and a voucher to pay for it? Maybe some weird stock control thing.
I always use simple language that ‘should’ translate across using Google etc,. My go to copy/paste reply is: “Part is broken. Cannot use. Please refund or please replace. Thank you kindly”. AliExpress gives the seller 3 days or so to respond, after which they step in and often refund you. With low value items a return might not be necessary. £2 for a new strut is a good result for you though, although £0 would have been even better…😉
"Yes"
I had this for a bike shifter I bought that had a defect after a while, I did think it was odd. Maybe it makes it look like two sales 🤔
