GR Yaris HJS Downpipe with ECE-approval
It's hard to get consistent 50-130 times... And 10-15hp is quite difficult to measure, maybe easier 150-180 in 4th...
Butt dyno says that peak torque has moved slighly upwards and now around 4500rpm? managed to drive bit more with the cat installed and car feels great overall especially in higher speeds & rpms.
I’ve gotten in touch with HJS to question whether they have improved their product design to avoid all the issues described on this an other forums. No reply from their side yet and it’s been a good few days already.
I’ve gotten in touch with HJS to question whether the have improved their product design to avoid all the issues described on this an other forums. No reply from their side yet and it’s been a good few days already.
Perhaps if more of us contact them with similar questions, it will make the message stronger. ;)
Some findings:
- car feels lighter on its feet, easier to get going. More or less throughout revrange.
- Spool/lag test. When letting revs drop on closed throttle to 2k rpm in 6th, then floor it. OE it takes 3-4s to reach full boost, with HJS about 1,5-2s. Clear improvement.
- Install was 3h for workshop with good mechanic that never saw a GRY up close. Toyota workshops that insisted on the official work method of changing OE cat wanted to charge 2-3x more. FYI
So, from HJS themselves,
‘we have only a few days ago heard of problems with the pressure connection. Therefore, have reacted, the HJS pressure hose extended and supply from now on a suitable hose adapter with. With this update, the problem should be solved!’
Having driven some more, I must say for me it makes a bigger difference then expected from the numbers. Just watching the boost gauge, where before you could see the needle building the boost with some creeping the last bit to build the last bit of boost, now it looks more like a quick needle sweep that just stops dead at the requested boost, no drama.
Also the engine/turbo feels less strained and less whooshing from the exhaust (which became a little louder esp on cold start), ironically making it feel slightly less fast as it's not trying as hard....
(edit: I can observe all this since I have ESE off)
I'm happy with the HJS, exceeds* my expectations of improved response.
*Disclaimer: I also put in the Forge carbon inlet duct, the lower IAT's might help my impressions so perhaps others should agree/disgree with the above, although no different then running car in slightly colder weather, which is more or less what I'm comparing with as ambient temps are up since installing ...
I hope there will be a solution for OPF / GPF as this is the second big....or the bigger bottleneck at exhaust side. If I see the gains with opf delete I could cry.....
And HJS is from Germany and still no tuning part for this....argl....
But nice review @ onehp, this is def. on my wishlist
With hjs the top end doesnt feel that restrictive anymore so maybe not true need for extra sport gpf? More open exhaust might of course give small additional gains too
To us Germans any ECE or TÜV compliant part is a godsend.
Even if it might not be the most essential thing, being able to change the gpf against a less restrictive aftermarket part would just give a bit of extra flexibility and potential. :)
If I'm not completely mistaken HJS looked into the OPF and for some reason decided it wasn't worthwhile to try to improve upon? AFAIK nobody has actually tested how far a HJS + OPF can be pushed, some say the cat is more restrictive than the OPF (was it you @Phil1291?)...
If thats true, that cat is more restrictive, I would be ok with it. but I think its switched, dont know where I got this information, might be that Im wrong
Also need to be realistic ref. ECE and TüV and the delta an upgraded OPF may give while keeping emissions.
As it looks now, HJS cat upgrade and OPF delete have very similar looking dyno graphs, which should mean a OPF upgrade will be less effective.
But only indication as dyno comparisons are a science by themselves....
This is great to hear. And it seems HJS reacted to the initial problems. However, I still feel that is a tricky part to be replaced for someone who’s never done it before…so I need to find a place in Spain where to fit, with some previous GR HJS experience… in order to go ahead with it… difficult, not imposible!
It's not rocket science. Just a good workshop with a good mechanic. Replacing catalysers has been done before, would have done it myself if I still had access to a workshop...
I know. But it’s not an easy access one and it’s a good few hours work if you don’t know the car…let’s see
I noticed an update posted on the old forum on 29 October 2022. Tralien mentions he just installed the HJS and found the hose to be long enough. This makes me think he got the updated version.
However, the part/pipe of the HJS cat that is meant to slot in the OPF section was too long and required cutting.
So many reports suggesting poor quality control at HJS! If/when the time comes, I'll be checking what Armytrix offer at that time, as they are the only other sport catalyst I'm aware of with a chance to be street-legal in the UK; and in fact 200 cpsi, so more free flowing than the 300 cpsi HJS one.
From what I gather the Armytrix is not compatible with the stock GPF, in other words it’s a full turbo back system, which could end up being quite expensive.
