GR86 Heel and toe. GT86 Vs GR86
Any tips on heel toe?
I've watched youtube vids, read up and tried it but have never been able to do this. Think maybe it's time to learn in the 86.
I just can't seem to blip the throttle with my heel or with the side of my foot when breaking to match the revs.
Anyone who has a link to an instructional video or any tips appreciated.
Cheers.
Cheers.
I wrote this article back in 2003:
Driving Techniques 2: Heel and Toeing
When driving on-track and equally on the road there are always tips and tricks you can learn. Often mentioned but not always well understood is that of heel and toeing. Before I explain what it is I am going to mention the benefits and the reasons behind it. This technique is aimed at keeping the car on the smoothest possible transition from braking before the corner onto corner entry. It’s main aim is to help maintain the balance of the car whilst simultaneously allowing maximum braking.
What heel and toeing is, is essentially a ‘blip’ of the throttle to match engine revs whilst changing down a gear and braking. All at the same time of course! Sounds difficult, but with a bit of practice, not only do you get round corners more quickly, but you are also much kinder to your car’s gearbox, clutch and engine.
Probably the easiest way to explain it is to take you through a virtual corner. So here I am approaching Redgate at Donington. I’m in 4th gear at around 105mph or so. To take the corner I need to reduce my speed to 60mph and be in 3rd gear. I am still accelerating as I am approaching the corner. At the braking point I put the brakes on very hard to slow down in as short a time as possible. Now, timing is key to doing this well. As my speed drops just below 75mph I push the clutch down and change into 3rd. before I let the clutch up, I roll my right foot (which is still on the brake) and turn it slightly anti-clockwise to ‘blip’ the throttle. This sends the engine revs up and as I let the clutch out the engine speed matches the road speed in that gear. Next I turn-in to the corner and get back on the power easing the throttle on to balance the car for the exit of the corner. Two main advantages here; firstly the car hasn’t been unbalanced by me changing gear and braking. Secondly the net result is that I’m on the power earlier and everything is that much smoother.
So what happens if I don’t heel and toe? Well I enter the braking zone, brake hard, then as the speed drops I change down and as I let the clutch up the engine revs suddenly soar, which in turn unbalances the car as the rear goes light and I have to deal with all this before I turn into the corner!
A year ago at Bentwaters I experimented with not heel and toeing at a tight left hand corner. It was a second gear corner and I found that if I didn’t heel and toe I actually locked the rear wheels as the clutch came up!
So in effect when you heel and toe you are pressing the brake and accelerator at the same time. This is the trickiest bit by far, how to maintain consistent even braking and in the middle of it blip the throttle? As I described earlier, I like to roll the outside of my right foot onto the throttle. This is certainly the way to do it with the most feel. But if you have standard pedals then you may find they are too far apart to do this easily. I have a Sparco pedal set in my car for good reason and that is to put the accelerator and brake closer together so that I can roll my (narrow) feet more easily.
If I’m driving a friend’s car I use the ‘other’ way. Literally use the ball of your feet to press the brake and kick the accelerator with your heel. It’s less easy to keep a constant pressure on the brake doing it this way, but it gives the same results as rolling your foot. It may be less exact but it works just as well.
One of the best things about heel and toeing is that you can practice it every time you drive your car on the road. Please remember though that the first few times you try it make sure no-one is in front of you. Try it at slow speeds on a quiet road. Cruise along in 4th then try the technique going into 3rd. Better still simply sit in your car and look at your right foot on the brake pedal see how you can push the brake and hit the throttle as you do it. Make sure that your foot is in no danger of slipping off the brake. I was practising this a few years ago and tried it approaching a roundabout. I wasn’t going overly fast but my foot slipped right off the brake and I had to get on the brakes pretty quick to stop in time! So be careful!
Lastly, in order to help heel and toeing, think about getting a pedal set. You can buy a funky Sparco Aluminium set for under £20. Make sure it is a ‘bolt on’ set and not one that clamps over the existing pedals. What you need to do is to take the rubbers off the brake and clutch and drill through the remaining metal pedal. Then it’s a matter of bolting the pedal cover to the pedal. Make sure that the brake pedal cover is absolutely secure. You don’t want this to come loose! By law there is supposed to be 50mm between the brake and accelerator. It’s very much up to you if you keep to this. You’re unlikely to get prosecuted if they are closer than this distance and you would be pretty unlucky to fail an MOT because of it.
To heel and toe well and to drive well, you need to have the maximum feel through the pedals as possible. A lot of people drive in trainers and while this may be comfortable, because of the thickness of the sole it literally robs you of feel and feedback through the pedals. Okay the clutch isn’t all that important but the accelerator and brake certainly are. Try to wear as thin soled shoes as possible. Best is of course racing boots as they are designed solely for this purpose. They do cost, but in my opinion they are worth it. Expect to pay around £30 or so for ‘clubman style boots’. FIA approved nomex boots start around £60 plus.
Lauren :)
Cheers.
I've watched this before and thought he explained it well.
This one?
Also think there is one that actually moves the pedal closer.
That's the one. It makes the pedal a little wider overall and has that "extra" extended part on the left. Just enough to make it right for me.
That's the solution I like. I think it will be very effective. Because no matter how many solutions I looked at on the Internet, all of them caused me certain doubts. One was an animated explainer video about the main differences between GR86 and GT86. It seems to me it is necessary to get well acquainted with the article Driving Techniques 2: Heel and Toe, it obviously will not be superfluous.
Added the cusco accelerator pedal extension and I am getting better (coming from a total novice)
I find heel/toe very difficult in the GR86; have been heel/toeing for 20 years.
IMO the accelerator pedel is too low or the brake pedal is to high.
The (free) fix is to adjust the break pedal lower (and the switch too). There are a few discussions on other forums. Basically loosen the lock nut, remove the pin, twist the cleat 3-4 turns closer to the firewall, lock up again and install the pin. Then adjust the switch accordignly. This is the solution.
Alternatively, raise the throttle pedel up, for which there are various kits.
Thats my post in the other forum. Glad to answer any questions anyone has. Simple (but cramped...) DIY.
Looks like there’s loads of adjustability potential so it can be set up to anyone’s personal taste.
Has anyone ordered the Versus Engineering throttle bracket?
Details here: https://www.verus-engineering.com/shop/throttle-pedal-spacer-brz-frs-gt86-gr86-380#attr=42,129
Vid:
The Versus engineering extension is a great add on.
Fixed not only my heel and toe issues (can't actually reach without moving my whole body) but it really smooth out my launch and gear shifts. I guess I am just used to the less offset pedal height and the GR86 just too different for my muscle memory.
