GRinning
Devoted member
- Jun 27, 2023
- 39
- 142
Hi All,
A friend of mine managed to get chatting to someone who helped setup a GR Cup race series, and asked a few questions about how they prep the cars. Hope the following is helpful!
“He said the gearboxes are tough, but fail quickly with the factory oil, particularly the synchros. He recommended to monitor for debris from the synchro in the gearbox and to change the oil, they use Ravenol 75w140.
The engines they fit with baffled sumps (possibly this) and additional oil pressure warning sensors. They run 5w30 thickness and said he hasn't seen it as a problem.
Suspension, they run
5.5° front camber with 2° toe out,
1° toe in rear
2.7° rear camber
The factory clutch is another failure point. Although he said it's only the Friction plate material that's poor, they keep a spring damped friction disk not solid, but they run a better friction material. He couldn't remember the brand.
Lastly, the sliding collar on input shaft to the gearbox that gets moved by the cluch fork. He said the cars all wear here and you should monitor it. On track they often replace gearboxes (2hr job apparently) but on a road car it's just something to keep an eye on when you change the clutch.”
1° toe in rear
2.7° rear camber
