Bluemanc100
- Jul 4, 2023
- 711
- 848
- 128
Cheers… I have a 1/4 drive torque wrench that goes that low8NM for the bolts holding the clutch assembly to the chassis. Too low for my torque wrench, so just a nip up .
In the interest of balance. I don’t understand why anyone struggles with the clutch. Feels normal to me.
We have multiple manual cars in the household and I often jump from one car to the other. The only one that takes a minute to adjust to is the Aygo as the clutch is cable not hydraulic. GR clutch feels great in comparison.
I used to race a Caterham with a cable operated paddle clutch and high lift cams, now that WAS tricky trying to be smooth at low speed but was easy enough to learn.
I’ve just listed 5 of these lighter springs for sale in the classifieds if anybody is interested.Thanks to @ZN8 I've now been able to fit another clutch spring which is about 75% lighter than stock (LC095L02M) spring, as he ordered a lighter one but was happy with the MTEC equivalent strength, and was happy to donate the unused one to me.
The result is about as I expected....it's improved the feel of the clutch even more. It's not as big an improvement as moving from stock to the MTEC equivalent spring (which is about 58% weaker), but I now can't feel the point where the clutch pedal pivots on the spring at all. It's now weak enough that it doesn't seem to be providing any meaningful assistance to pushing the clutch down, which means that most of the resistance I can feel must be from the clutch itself.
The clutch pedal does feel heavier as a result, but it's by no means a problem or obstructive. No heavier than most other manual cars I've driven. As I said a few months ago, really it's just averaging out the force required throughout the whole pedal travel; it doesn't feel like the pedal effort changes when you reach that point where the spring pivots from pushing the pedal up, to helping push it down.
I can see why many in the US ditch the spring entirely...that would give you maximum feedback by ensuring the only force pushing back against your foot is that of the clutch plate itself. But of course you'll end up with a mushy pedal as it won't return to its top position. I guess the ultimate solution is to fit the weakest spring you can find...literally just strong enough to keep the pedal from being slack.
Brilliant, I was considering doing this myself after enquiring about buying one off him.As Bluemanc100 has sold all his springs, I have just put an order in for 6 so will be able to provide spring to other members who are looking to do this mod. Once I have them I will put them up in the classified section and members can PM me. Happy to do my bit for this forum.![]()
Hi @Grblue86 Off topic.. could you share the details of the floor mat in that photo?Installed my sorting today. But inadvertently I twisted the rod to get into place when I was fitting it back. But I don't know how to tell if it is too far down, it drives well though. Any ideas how to tell if this won't cause any issues down the line?
Amazon product ASIN B08NF5CB29Hi @Grblue86 Off topic.. could you share the details of the floor mat in that photo?
Do these fit well as they are advertised to be for the GT86?
Not perfect but they do their job. I cut the drivers side near the dead pedal as it was not sitting flat with the floor there. The ones in the back may need trimming a tiny bit as they catch when the seats are moved back and forthDo these fit well as they are advertised to be for the GT86?
Thank you.Not perfect but they do their job. I cut the drivers side near the dead pedal as it was not sitting flat with the floor there. The ones in the back may need trimming a tiny bit as they catch when the seats are moved back and forth
Was it Dynamo? Easy when it’s LHDBetter way is to get a young and flexible friend to do the job. I found one who did it for me without removing anything except the spring
Bye for now Fred
