NunoHenriques
Devoted member
Went for a longer drive yesterday with the pedal commander and I must say I will keep it. On my way back I turned it off and I could definitely feel the lack of throttle response on the first 30% or so of the throttle.
Getting out of junctions is much easier as you just need about 5% of throttle to get it to stable 1.5/2k rpm’s, however you need to be carful as it is a bit too sensitive. I always had some issue parking the car in my driveway backwards because it has a small bump and with the Pedal commander it was just easier.
I tested all the mods and in my case I won’t be using anything else then the city mode.
There are 8 responsive modes within the city mode, for a normal drive -4 (responsive) is the way to go, similar to stock but less input delay. If you want to get more sporty 0 (or even +4) it’s better, but be careful if you have tc/vsc off as it will put you sideways pretty easy (it was raining yesterday, so it could be different when dry)
Even thought it reduces the input delay you can still feel it a little bit, but better.
Also, heel and toe became easier, but because I was used to the stock now I find my self over revving, but that’s just a case of getting used to it.
Having all of this said, this goes down to personal reference, I believe some of you might not enjoy, specially if you are already used to the stock, but in any case you always have 30 days to return it.
It’s a bit expensive (190£) but I prefer that to tune, as I can easily remove it in case I need to go to Toyota for a service or something.
I left the controller hidden near the pedal, since I can control it via Bluetooth app.
