GR Yaris GR Yaris S4
GRunt
Northern Germany
I was thinking about the integrale S4 and it's combination of supercharger for low to mid end torque and the big turbo with 4500 rpm boost threshold.
Would it be possible and beneficial to the GRY to run a twin charge? It would increase complexity and weight and parasitic loss. But on the other hand would allow more response, better power delivery and driveability.
To tackle the parasitic loss: there is the possibility of an electronic supercharger. I mean think about it. The next GR Yaris could possibly be a hybrid with the basis of the Rallye 1 cars. My mind bends around a GR Yaris with flex fuel and small light hybrid unit to regain brake losses and an electronic supercharger in combination to the G16E GTS and big turbo. This could run on E-Fuel, E85 or even pure ethanol.
Well that sounds quite complicated and is an clearly other approach as the GRY with it's beautiful simplicity. But also sounds interesting, with a lot of potential and maybe a future solution.
I'd like one for my Focus RS if it were possible, even if it was a low power output one just any little boost to help with the low down pickup as you say! :love:
:cool:
This is a setup I discussed with my tuner.
The sheer amount of R&D and calibration to get the setup drivable would be immense, and unless you are running a G25/30-600 setup or more they’re really isn’t going to be a lack of low down torque.
On the old group B stuff the turbo at the time probably didn’t spool until 5k, hence the need for a supercharger.
I think wait a few years and hopefully Garrett will do after market versions of their electronically assisted turbos that are currently going in the likes of the new AMG 63. That will be the sweet spot vs an old school twin charged system.
The system from the m139l engine was exactly what brought my from the S4 to a Hybrid GR Yaris.
The Garrett EAT is a simplification of systems like the old S4 or the T6 from Volvo or the VAG group twin charged engine like in the RSQ7. Instead of using a electric super charger it uses a electric motor directly integrated between turbine and compressor in combination with the hybrid system.
An other possible solution would be a VTG turbo charger like the porsche one.
