GR Yaris GR Yaris Rally1 Hybrid Specs
Michael Knight
Finland
Gazoo Racing has updated the spec sheet for 2022 GR Yaris Rally1 car
It states McPherson front and rear so Rally1 car has worse geometry setup than GR Yaris?
Specs
Engine typeIn-line 4-cylinder turbo, direct injection, Hybrid Power Unit
Engine displacement1,600 cc
Maximum powerOver 500 PS
Maximum torqueOver 500 Nm
Bore / stroke83.8 mm / 72.5 mm
Air restrictor36 mm, following FIA regulations
Gearbox5 speed mechanical shift
Gearbox final drive4 wheel drive, 2 x mechanical differentials
ClutchDouble Plate Sintered Clutch
Front / rearMacpherson
Suspension travelDamper travel 270mm
SteeringHydraulic Rack and Pinion
Braking systemGravel 300 mm, Tarmac 370 mm
Length / width / height4,225 mm (incl. aero device) / 1,875 mm / adjustable
Track widthAdjustable
Wheelbase2,630 mm
Minimum weight1,260 kg
Top speed201 kph (Ratio Specific)
Difference in dimensions to stock:
70mm longer wheelbase,
230mm longer overall (probably the spoilers)
70mm wider
20 kg lighter.
brake disc diameter tarmac vs gravel propably typo as they use 15'' wheels for gravel.
Interesting that the wheel base is extended.
McPherson is pretty typical for rally cars? It’s easier to have long wheel travel than with double wishbone. Your upper wishbone would have to half the width of the car.
Interesting charge pipe design - expanded to cool the air
So as per these specs, the GR Yaris Rally1 car has an inline 4-cylinder engine. Anyone know what this engine is, does it come in any form in any Toyota production car?
It isn't. 300mm fit 15" wheels.
It's the same engine from the previous WRC Yaris.
Typo referring to at some point the disc sizes were othervise, 370mm for gravel end 300mm for tarmac but seems they've fixed that.
if you compare the bore and stroke between rally1 GR Yaris and our GR Yaris, there's quite abit difference.
Street version has much longer stroke giving maybe a better torque but less of a high revving engine.
Rally1 GR Yaris (mm)Regular GR Yaris (mm)difference
Bore83,887,5
4 %​
Stroke72,589,7
24 %​
No, wrc engines are one off(not sure this is the right word), nothing to do with production engines, except they too have pistons ect. I think it was before 2018 they didn't even manufacture their own wrc engine (for Yaris WRC)
Would be nice to get technical detail of that wrc 2021 car as it is GR Yaris based it would be the ultimate blueprint..
It looks like its got the letter box centre exit exhaust, see where the GR Corolla takes its from!
