GR Yaris GR Yaris Mk2 vs Mk1 technical differences
Michael Knight
Finland
Is there a clear explanation where does the power difference come from with mk2 GR Yaris?
They have said that pistons or piston rings are revised part? Assuming the air intake and exhaust including cam profile is the same, so this would indicate they have upped the target boost in mk2? As they agreed to provide similar power gain to GRMN mk1 models.
Valve springs are likely GRC spec aswell but as seen in videos there is not very big difference between the two variants, actually.
Which means that for longer runs the power of these models would be more or less similar, due to added heat etc.
Of course mk2 is improved platform as a whole as it has improved engine parts, but in the same sentence the difference is not night and day as we have seen with GRC engines.
Has anyone found EPC for MK2 already as it would give good insight on revised parts?
Improved engine spec could give engineers to rise the knock tolerance, torque limits etc. a bit that results higher target power.
but on long run, as heat is more or less the main enemy here the real life performance is likely more or less the same.
Heat is the enemy, for sure. That's why they installed the sub-radiator, I'm sure. Probably has the GRC oil heat exchanger, too.
My car has the GRMN flash from dealer, which bumps torque to 390nm, and to be real, a 30hp bump to 300 isn't really much to do, and requires no engine mods. As far as pistons go, even with the Mk1, 2020 pistons are different than 2023. Toyota does this stuff with all of their cars, changing/upgrading parts on the fly, and not waiting for a new model year. This isn't to say that there's anything wrong with the first engines, just that they improve things as they go along. Although when I hear things like "lighter weight pistons," I kind of cringe :LOL:
I'd bet that on a 3km tight hill climb, Mk1 vs. Mk2 time difference would come down to the driver. On fast circuit, it's only showing a little quicker...unless it's the auto, and then all bets are off. That thing is quick.
Is there a method to identify and list, by date of manufacture, the specific changes made to pistons and other engine bits?
Just curious. My car is a 2023 model (number 21940) with a manufacture date of October 11, 2022.
It doesn't mean a lot though, my Tojo 4wd was the first of production with 'new' pistons. Previously there were known issues with cracking... mine cracked too. Later part number but identical to the previous piston just a different supplier. There may have been material changes but the failure in ine was side by side the same as the early pistons.
Not that I know of. Only parts numbers that are/were superseded by newer numbers. Like the oil pan for your can and mine has a different part number than the early one. If you order a new pan for an early one, you'll get the newer pan. What's the difference? Have to have both and compare. Info on exactly what's been changed is hard to come by.
Expecting similar changes as the GRC? Which were:
- different PN Turbo, possibly higher flow turbine? Tbc
- Larger exhaust valves, giving higher flow and power.
- New exhaust that is bit higher flow? Tbc
- Some more boost, approx 10%? Pretty sure it has to be...
not sure if valid for GR mk2 but did a comparison from the data shown in Nemtec video for GRC Boost target and actual.
Seems to hold boost higher in high rpm. Holding almost 1.5bar to redline would definitely make the stock car feel more brisky.
