sixtentouge
- Aug 28, 2023
- 206
- 844
Posting some detailed pics because I don't see much info. Originally bought it just as a "whatever." Only cost ¥33,000 from GR Garage.
I didn't think there would be much difference because I've tested the car with completely blocked stock (black) pipe, and it didn't make any difference, blocked or open.
Cruising at a sustained 2,000ish RPM on a dead-flat road, 33°C and 80% humidity. 30 second capture after all temperatures have stabilized shows a 4°C temperature increase over ambient ("Ambient Temp For AC" sensor is the one in the grille and not in the sun for this test) to the airflow meter ("Intake Air Temperature" in the MAF sensor). The data I have for the black pipe never showed less than a 6°C rise, usually a little more.
6-second pull in third gear from 3,000rpm to 6,500rpm shows a 12°C temperature increase over ambient, where it pretty much plateaus. Same conditions for the black pipe hit 50°C.
Was there a difference? Yes. A marked difference in second gear from 5,000-7,000rpm. I thought I was done, just taking a few AIT captures for fun, but never expected any tangible difference. Will now have to hook up high-speed data logger and quantify this...
But first guess is that the ECU is pulling a significant amount of ignition timing due to the IAT generated on a 33°C, high humidity day. Even 5°C cooler at the MAF sensor is likely putting back some timing. We'll see soon...
This car has some titanium heat shielding and ducting that keeps the radiator air away from the lower duct, and at full throttle, the MAF sensor IAT runs pretty close to ambient (and makes significantly more power). Everything was removed for this test, and it was just a back-to-back, black tube followed by red tube. 60-second swap.
