GR Yaris Getting more hp out of my Yaris GR RZ
Jonchin
Hello guys, i just recently purchased a yaris GR RZ 2021 from japan but i want to get some more hp out of it. I would love to get 300+ so if anyone has got there yaris to that i would really appreciate it if you give me some advice also would love to remain reliable not trying to get anything crazy 300-320 would be perfect.
Im planning on buying
Lamspeed exhaust (would love recommendation)
Cold air In take
I was reading up that if you want to get the most out of the engine i need to change the ecu so i read that the motec is pretty good “plug and play” so i would love to know how plug and play is it ? Would i still need to take it to a tuner? Or they would have readily available tunes? (Live on a island and dont have access to alot of tuners)
Also watched a next video that said if you are going to change ecu to get more power it would be wise to change the valve springs and if you change the valve springs might as well change the camshaft
So after doing all of this how reliable would the engine be? (This would by my weekend car so i wouldnt drive it everyday)
Do i need to do all of this to get 300-320hp
Would really appreciate the advice
As far as I know you don't need to swap to an aftermarket ECU anymore. ECUTEK can flash the stock ECU. I think you need a tuner regardless though.
I don't think you need to swap camshaft or valve springs if you're staying in the 300-320 range.
You could also try a DTUK stage 2 tuning box together with an exhaust and intake. Should give you north of 300 with minimal effort.
Yeah, a MoTeC is certainly not plug and play, that's for sure 😂
Just remap the standard ECU and sort the breathing out a bit and you'll be there.
It's not the headline HP increase that makes the most difference though, it's the increase in mid-range which gives most advantage on the road.
Plus the benefit of having more consistent intake temps so the the ECU doesn't hobble you if IAT gets too high.
Reliability comes from not overdoing the torque, and keeping temperatures in check with mods that help breathing (both in and out) and cooling.
If you can't visit a tuner, all you'll need is a GPF back exhaust, Eventuri/ good intake and DTUK V2 box to get you there. I'm not sure where you are in the world, so you may not have an OPF/ GPF in your region anyway.
Jamaica
https://www.tegiwaimports.com/scorpion-gpf-delete-toyota-gr-yaris-20.html … like this then i put a exhaust like this?
If its from Japan then you don't have a GPF, so this wouldn't fit, and the GPF delete would not be necessary.
Since i dont have GPF which exhaust would you recommend
That's entirely individual on taste, age, neighbours, budget, tracking or not etc. Many to choose from....
Wanted to spend 1500-2000 usd , nice growl not crazy loud but still loud enough
I was looking at this
Will be quite loud... 70mm piping if you don't want drone like 3"/76mm does.
Mst intake vs eventuri
I have MST myself, because it makes more noise. I like loud induction noises. If you want a bit quieter then Eventuri. Both good choices. MST is a lot cheaper.
Both MST and Eventuri showed good results in testings. However, I think closed system like Eventuri would be better for temps.
As for the exhaust, HKS exhausts generally have good flow and are not too loud.
Pair those with downpipe (for example HJS) and DTUK, you'd be well above 315hp/420Nm I guess on a Japan spec car.
