So installed the Forge Turbo Inlet Adaptor kit yesterday. FMTIA8
Instructions are pretty good link
Some added tips for smooth install:
- Get a second pair of hands to help. Preferably small hands.
- Have/burrow a good assortment of 7/10/12mm sockets with extensions, small ratchets, flex joints etc so you can find a tool that works. Just one type will leave you stranded if it doesn't fit, small spaces...
- Be sure to get the E8 torx socket, makes life easier.
- Get good lighting
- The intake goes under the vacuum line that goes from the solenoid at the top left of the engine, down to the rear of the engine to the waste gate actuator. I recommend to remove it from the solenoid end (wiggle it off), otherwise there is a risk when manoeuvring the turbo inlet piping in and out you pull it off from the WG actuator side which is a bit bigger pain to get back in place.
- You will reroute the vacuum line to mentioned solenoid from all the way to the back right to back left, be sure it cannot chafe on anything metal or sharp edges.
I did the install mostly from the top, and rest from the wheelwell opening where the steering rod goes (so right front wheel comes off). Moving the coolant tank out of the way is a very simple but very effective way to gain access from the top to the turbo inlet, which has to be my top tip. Just remove two 10mm screws and move it out of the way. On RHD there might be more stuff in the way, but works a charm on LHD.
- Get good lighting
