I keep mine for a rainy dayIt's why my sprayer is good when things get hot
I must get around to finishing installing mineIt's why my sprayer is good when things get hot
I'm thinking a little elbow won't do much, there still is a flow through the engine bay that will make it miss its mark.I'd say bugger all difference. It's all on the cooler side. Just easing off the throttle for 5 seconds at 100mph + before braking a bit later on a straight will make more IAT improvements from charger soak than any pipes or scoops will on the inlet side.
Go for itI'm thinking a little elbow won't do much, there still is a flow through the engine bay that will make it miss its mark.
Backroad driving on very small roads is different again too, so I'm set on reducing the >+20°C above ambient charger temps as much as possible. From my findings so far I've now set my mind on the Forge.
Same for normal driving. I enjoy driving very small very twisty roads. Meaning short bursts of full throttle, closed throttle (no IC flow) and relatively low speeds...Mine is never that much higher on the road unless I'm in traffic. It seems to sit about 4-6 agrees above ambient max.
That's massive. HJS should have a similar effect, albeit maybe not exactly as big a drop. Stock cat1 temps are so high, I'm amazed a box only would render any meaningful power and if it does it's because it is running hotter then it should for anything else then single pulls....Maybe my de-gpf helps general engine bay temps, cat 1 temps are easily 200-300 less than before on average I'd say.
I'll be interested to see what you discover. Heat is certainly no.1 enemy of this car.
That's massive. HJS should have a similar effect, albeit bit not as big a drop. Stock cat1 temps are so high, I'm amazed a box only would render any meaningful power and if it does it's because it is running hotter then it should for anything else then single pulls....
Me too, after my little plan is done I hope it runs a lot cooler = more fun and healthier.
I've never used a 'programmable box'. I'm sure you'll have researched them so should be able to answer this question.So basically sticking with the original plan and aiming for a programmable box.
Indeed, adding more boost isn't a replacement for hardware improvements. But those improvements do remain even if you afterwards perhaps up the boost a bit in chosen places...Sometimes less boost is more.
