GR86 Engine Failure
Are you concerned about the GR86 engine failure stories emerging?
  • 1. Not concerned - if it breaks Toyota will fix it
    Votes: 48 39.0%
  • 2. Slightly concerned - but not losing any sleep over it
    Votes: 54 43.9%
  • 3. I’m getting worried - I want to use my car on track
    Votes: 13 10.6%
  • 4. I’m very worried - I’d planned a lot of mods and lots of track use
    Votes: 2 1.6%
  • 5. I’m that worried I’m cancelling - and off to buy something else
    Votes: 6 4.9%
  • Total voters
    123
Either way it's what warranty is for. I also changed oil early to be sure, check the levels regularly, always let it warm up and cool down properly and it could still occur. The drop in oil pressure was affecting many tracked ones with more grip than stock. If I tracked regularly I'd think about baffled sump and even options on that have fizzled out too.
I'd recommend cooling and baffled sump for track, baffled sump alone won't suffice
I think its because they made no difference, the most effective way to maintain oil pressure is to overfill by 0.5-0.7 litres from what I've read.
I do know of someone who had an 86 and following a track day the engine is knackered, not RTV but from oil starvation I think he said from prolonged right hand high speed cornering. Ended up with a knocking sound. I think I've read similar issues from trackdays on some of the US forums.
He's an engineer and suggested it needs thicker oil for track days, the standard is too thin causing the oil starvation.
If I was to take my car on track I would definitely want to put thicker oil in it. 0w20 is perfect for the use profile on normal roads and our climate but I wouldn't be comfortable with it on track.
Thicker oil is not a fix for an oiling issue in long corners.
Low pressure in long corners would most likely be caused by the oil not returning to the pickup. If there is no oil at the pickup it doesn't matter what thickness of oil you run.
Thicker oil is more likely to assist where you are losing film strength because it's getting hot.
I overfill 0.7-1 litre in my car, I don't bother to take out the oil after the track day.
I ran a stock oil cooling at Spa and found the oil temp to hit 125c and rising. I was running 0w30 Mobil 1. From the next oil change on, I will be running Titan Race Pro S 0w30.
I considered changing to 0w40 if the temps didn't improve much with the Greddy Oil Cooler.
Did a track day at Bedford with the Greddy and happy to report the oil temp didn't pass 105c even after 8 hot laps. So will continue to run 0w30 and change oil every other track day.
Oil starvation on high G's right handers 'IS' an issue but I only think this is an issue if you can can generate these high G's. Unless your car is set up to chase lap times with proper Track Suspension and sticky wide tyres, I doubt you will generate the G's to worry about oil starvation.
So far, all the oil pan baffles on the market have not been able to cure the oil starvation issues. I think someone needs to make a redesigned oil pick up but I think the issue with that, is the engine needs to be stripped to fit it. The current oil pick up cannot be changed just by taking off the sump pan.
In relation the the poll, I think my car with the oil cooler fitted, I doubt Toyota will warranty the engine if anything happens. Hopefully, it will never come to that!:censored:
Here are the vids of the 2 track days I done:
It'll be the 900brz/Verus revised oil pan that many of us will be waiting for, assuming it's at the very least just a bit bigger in volume, but seems to have helped. Got my eye on that development.
Don't think any baffles have really helped except syms (paired with their pan perhaps?), so overfill has been the main workaround for now.
Thicker oil + cooler helps with higher nominal pressure, and may well mean that a dip in pressure isn't as severe but who knows.
Plenty of info on gr86.org on it!
Surely an accusump is the most logical solution for prolonged track driving. Never had one myself but since I started dabbling in track driving 12 years ago I've only heard good things about them.
Accusump is the correct mod for a track car. In my opinion, anything that is going to have bearable ride comfort on the road, is not going to generate enough G to have to worry about the low oil pressure issue.
At the risk of 'waking the dead', I wasn't really sure where this would fit, so thought it might slot in here as it's basically an engine 'failure' of sorts, albeit caused by a particular 'mod':
Post on Reddit today regarding the spontaneous ignition of their GR86. Turns out that he had a Flex Fuel Kit modification fitted (not declared via insurer) which, according to some within the discussion, was the likely cause of the 'bang' heard from under the bonnet before everything went up in flames. A proper brown-trouser moment I think!?
Update: The user has now deleted his original post (after much advice from others) as it referred to him having fitted this kit. Obviously trying to save himself from a $0 insurance claim ... The photos below are from the original source.
Is this mod not fairly common in the US mostly due to the widespread abysmal low octane fuel sold at most of their “gas” stations. Unless I’m mistaken and their octane grading/rating is different to ours here.
Yes and a lot of manufacturers sell cars that are flexfuel models like VW, Ford and Chevrolet.
I'll add my part.
My car have a complete short block replacement and also cam sensors replaced under warranty. The middle of my original block was leaking oil non stop.
That issue did really put me off touching the engine, but with the replacement block run in now and is happy that the issue is fixed.
The GR86 is gonna stay as a 99% road car and I have a dedicated track toy for those sunny track days. Not gonna worry about oil pressure or oil temp for now.
