GR Yaris ECU errors with sport cat
FrakassoR
Devoted member
France
Hello
I've installed a Cobra sport Cat (ref TY29) and i don't have error on screenboard.
but when i check with carista, 2 errors are present.
i've used this part for second sensor
if anybody have instal the same part (or Milltek or other) and can say me if he have the same situation or not ?
thanks a lot
Hello
Are you still using this oxygen sensor?
Or did you switch to something else?
If yes, what do you use?
I bought a whifbitz down pipe (for racing) but I don't know how to eliminate the Cel error.
Thanks
My last car needed a sensor extender like the one above to get the sensor into to 'cleaner air'. It was basically an inch of pipe threaded internal for the sensor and external for the pipe.
Thanks for the answer,
I'll order one then.
As far as I can see, the pressure pipe and tube are original. does it fit well?
Or you have to order something for that too?
Do you have any advice or important thing?
have you a link for whifbitz downpipe ?
yes, i've re-used original pipe & tube
yes, you have just to fixe original pressure pipe here :
Hi,
Do I have to install o2 spacers to both of the sensors or only number 2?
