This is basically the same car I have, same Akrapovič exhaust. The bangs aren’t excessive, and I think it’s the perfect amount. I was hoping Gr Yaris with Akrapovic would give the same sound
Oh really? That’s great! Do you have a video per chance? As I will be fitting mine with Akrapovič OPF delete and a full titanium Akrapovič system. Do you think it’s gonna pop here and there on mine too?Mine pops and bangs.. I fitted a turbo smart dual port dump valve and opf delete pipe with none Res system back.
Nice, that’s all I want, a pop here and there. I absolutely HATE constant popping when coming of throttle and stuff like thatIt doesn't usually. However last night I was trying to overtake on the Woodhead Pass in the dark. Floored it in 2nd then realised I couldn't see well enough so had to slam the brakes on. It went bang! All noise really. Thankfully it doesn't do the idiotic crackle and pop thing. If the exhaust is hot, you will get the odd rumble when coming off the throttle.
Intake helps you with Turbo sounds. Im with stock airbox and totally happy with intake puffs. Have taken out all the sound deadening that likely increases the sounds compared to stockI like pops but not all the time, it would be nice to have some when really hammering the car, but definitely not all the time or when just cruising around. But overall the car sounds great, love the "rushing of air" sound. Also the turbo sounds could be louder.
Same here with same setup! Can be quite loud. No idea of there are any flames thoughMine pops and bangs.. I fitted a turbo smart dual port dump valve and opf delete pipe with none Res system back.
