Oddly thats not the owners manual that came with the car, have found this part about disabling the key so will try thatGR86 owner's manual is here: https://www.gr-zoo.com/threads/u-k-owner’s-manual.1102/
There are instructions for disabling the keyless entry in it, haven't got a clue if it works as I don't have a car!
So once keyless is disabled it stays off until you reactivate it??Decent, that's the same as the Yaris, almost 2nd nature now![]()
definately a country thing, if you open the door and flick the lock switch on a rhd uk car it unlocks itself straight awayWonder why what's shown in the manual on page 114 isn't working. I definitely want to disable keyless entry, will be inconvenient to mess around with the key each time - particularly as I know my wife won't bother!
I see, that's annoying. Hopefully there is a way to do it somehow...definately a country thing, if you open the door and flick the lock switch on a rhd uk car it unlocks itself straight away
if it can be done its a coding job, putting the key to sleep is the only easy optionSo is disabling keyless entry an option - anyone able to confirm?
Or is the only option putting the key to sleep?
Yep, tried the methods in the manual, but none of that worked. Surely, the cars will be updated at some point to disable this as per the manual...if it can be done its a coding job, putting the key to sleep is the only easy option
