GR Yaris Cusco rear LSD assembly & differential removal
i ended up having to take the diff carrier out with the axles attached then remove them on the bench. it was just a bit of a pain.
but yeah, feels nicer than the stock open diff for sure
Sure needs some force and proper prybar to pop axles out. Goes back in much easier.
I read some where that threads on axle/hub mountin breaks easily since there is lock mechanism in hub/axle nut. Did you get it out OK?
Changed Cusco LSD to GR yaris last week. Removing differential was quite easy on jack stands.
- Muffler out.
- Rear sway bar removed from mounts. Would have been bit easier if I would have removed it completely but it was pretty tight on tie rod.
- Open 4 prop shaft nuts from ITCC. Before removing mark prop shaft position to ITCC and prop shaft flange.
- Support shaft with some strap
- Remove vacuum hose and electrical connector from diff.
- Rear diff is mounted with 3 bolts. One in rear, two in diff carrier. I used two ratchet strap for lowering the diff. One in front mounted to subframe, one in back mounted to muffler mounts.
- Not 100% necessary to remove drive shafts. You can open outer upper control arm bolt and tilt upright to get drive shaft out. OR carefully drop diff 15-20cm and pop drive shaft out. Then you must be careful not to break joints or diff side seal. But thats how I got it out.
- Wash the diff well before opening it. Remember to plug vacuum hose.
- Remove diff carrier from diff and open diff side cover
- Swap ring gear to LSD and adjust/shim back lash, gear pattern and bearing tightness. I'll do another post on shimming the diff.
- Check torques from WSM when you put diff back on.
View attachment 21763View attachment 21759View attachment 21760
Hi, when reassembling, did you replace all the bolts that Toyota classifies as "single-use"?
You should replace the crown wheel retaining bolts. Standard practice for these bolts when rebuilding a Diff.
Hi, thank you. I was asking for the bolts for securing the differential from underneath the car. They have to be chnaget as well - from Toyota manual... So that is why I am asking
The diff carrier bolts are single-use, torque to yield from memory. If the workshop manual states single use/torque to yield, new replacements are the way to go as they are pretty inexpensive.
Sure, you could always re-use the old ones but you wouldn’t get the same clamping force & run the risk of shearing. Then you’ll be in a world of pain.
