Spirited
- Jan 23, 2022
- 488
- 504
3 symptoms:
- braking steers the car to one direction a bit (might be unrelated)
- crack-crack noises on harder braking
- similar noises upon acceleration immediately afterwards
When braking gently, the car seems fine. I think I'm getting a feel as if it's steering to one direction, but no funny noises.
When braking harder (say 60-70%, not all my weight on the pedal) there are crack - crack - crack noises from the front. Whatever it is that's causing the noise, I think I can feel it as some sort of vibration on the brake pedal too. I noticed it at low speeds.
The acceleration immediately afterwards was also accompanied by
similar crack-crack-crack noises. I can't notice these when accelerating without having gone hard on the brakes before.
Any ideas as to what it is or what to check, much appreciated.
Car has Powerflex camber bolts (-2.75 camber front), caster kit (Powerflex front wishbone rear bush) & Goodridge braided lines.
Thanks!
Thanks!
