GR Yaris Coolant levels
corroded
I've only had this car since late October, it's probably just about halfway down the tank. Not overheating but I did notice there was some residue near it which looked a bit weird.
Normal usage or weird?
Was that warm or cold?
Mine is on the minimum mark when cold and about halfway between when hot which I believe is about right.
There are different compartments, if the level is unequal there is air in the system and you'll need to vent it with the plug to the left (not on pic). It's in this special document called... euhm, user manual I think it's called ;)
It's not entirely unusual that an air bubble finds its way out but if it persists after venting it needs to be checked.
mine it's at max when cold and about 1 cm above max when hot. I think it should be normal... but open to rethink it :)
I'd only just turned it on when I took that, maybe on a couple of minutes... Popped back to grab some screenwash as it ran out, that's when I noticed it was only about halfway up.
I'll take it for a drive tomorrow so I can check what it is like when it's proper hot.
When I got mine over the first service period (1-10,000 kilometers) it slowly worked it's way from Max to min when cold topped it up back to max and hasn't moved since
So I think part of this was just the angle the car was sitting at... On a flat surface it was higher. Actually when I looked even with the engine running it was above max.
Popped into dealer and asked and they removed a little bit. Makes sense since it was coming out the overfill sometimes.
