GR86 Cockpit: Delayed rev counter
AP756
Zookeeper
Staff member
South of Germany near Pforzheim
Not everything about my GR86 is as great as I want it to be. But that - in no way - prevents me from finding my GR86 worthwhile overall. I got the inconsistencies for free with my cheap fun car and I will keep all of them (the car and its mistakes). That's for sure :cool:.
I've been encountering a new problem for some time now, which is driving me nuts personally: The rpm display in the cockpit runs up with a significant delay. As a result, I can't shift the first three gears at 7490 rpm. The speed indicator is still at 7200 or 7300 rpm, the yellow speed warning has just flashed once and I hit the rev limiter again, which cuts the engine down hard. This is totally uncomfortable and I seem not to be able to "adjust" to this behavior. The speed and the yellow warning seem to be delayed (heavily damped and/or incredible slow) and therefore displays differently every time. Am I the only one bothered by this? Is that also the case with those who have the break-in period behind them? Is this a problem only found on some GR86s? Does it have to be like this? Am I too fast or is the display too slow? Or maybe, is this problem caused by silicone deposits? I look forward to your feedback.
Bye for now Fred
Hi Fred, I haven't noticed this problem on my car.
Just to be clear - you are saying the car 'thinks' you are at 7.5k RPM (actual engine speed) and the rev counter is showing only 7.2/7.3k as there is a delay?
I definitely not noticed anything like that.
Are you using track mode (with the different rev counter display) and could that make a difference?
Other way round: In lower gears the engine hits the rev limiter at 7500 1/min whilst the rev counter just shows 7200-7300 1/min and the rev warning (set to 7000 1/min) just blinks very briefly. This is independent from setting the display into track mode. This seems to be a timing problem of the display (too low refresh rate for the rapid change of engine speed in lower gears).
Bye for now Fred
Bye for now Fred
Interesting. I've not experienced anything like that myself.
Why are you looking at the dash when you are redlining? Just use your ears, surely
Any gimmick implemented in my car should work. If not it's just irritating and useless. As @FRAJ reorted the chance to hit the rev limit with your GR86 is much higher as with the GT86 and I'm quite sure this is because you wait for the yellow sign which mostly doesn't show in time. Will change the warning to 7500 1/min to never see it again... :)
Bye for now Fred
I think this might be related to rev hang, when on it and coming off sharply the revs don't fall like I expect them too almost picking up a little.
I lowered my warning beep now not hitting the redline occasionally.
Has anyone tried a lighter fly wheel?
