GR Yaris Brakes Seized On!
coded2112
Dedicated member
In fairness not really seized but did jolt when i first released the handbrake and moved the car...
First time it has been left undriven for so long... 9 days over Christmas and now there is a clicking i am sure it will wear off as the discs and pads bed in again, just surprised it has happened in such a short time...
I should have left it with handbrake off, but forgot! doh!!
Anyone else had this issue??
Yeah with all the rain and cold weather I have had that happen to all my cars sat still over the years over the xmas period. Not to worry! :) (y)
With a 'clonk' and off it goes haha! ;) 😅
Mercedes (AMG) can be a right pain, leave them with the slightest bit of moisture on the front discs and they really bind, first time it happened to me I was convinced something had snapped off when it let go, after that always put the car away with warm discs 👍 Difficult if your car lives outside though ☹️
Leaving the handbrake off during wet weather will help so long as you don't park on a hill. :D
Yeah, mine's done that a few times. Hell of a clonk as it releases!
Yep same here after 5 days or so. Same happened with my old Yaris, to be fair :)
Are your roads salted? Can make it even worse. Not necessarily the handbrake, just the disks can do this too on both axles...
Never known discs to go so rusty so quickly as these ones
Had this happen today car left under car port since 14th December, (Handbrake left off but still made a loud bang and then scrapping noise whilst film of rust removed by pads)
Had this issue as well. Washed the car on Sunday, rained on Monday, heavy frost last night. Took a bit of a push to get it going today because of the parking brake.
Not worried about it though.
Mine still clicks due to corrosion of the discs, sounds like the rears, i am guessing from being rusted on... and i have done over a hundred commute miles...
Hope it has stopped before the next service otherwise i am sure they will try and sell me new discs!! 12k Service due in less than 750 miles..
I think it's the rears on mine as the front seem to have cleaned up after 15 mile journey yesterday. It's much less the sound after the run yesterday almost sounds like metal to metal.
If it is the rears then a few hard applications of the handbrake may cure it.
Car is in for a 12k service today, i have made a comment to them about the brake discs on the rear, they seem very scored compared to the fronts.
I will see what they say, still can here a slight ticking from the corroded patch when the handbrake was "stuck" on, have made note to self to not leave it with handbrake on for long periods.
never known disc surface like these to attract the rust ,looks like the car hasn’t been used for some time even though it’s been couple of days
This ^^.
I had a Cayman S a couple of years ago and it used to live outside. It repeatedly failed the MOT on corroded discs even though it was in daily use.
Spray some diluted atom-Mac on the discs after washing the car or leaving for any length of time. Stops the discs blooming
They have said they are fine, but admit there is some scoring on the rear discs....
I will just make sure i dont leave the handbrake on again for any length of time...
Ironically Christmas was the only time it has not been used everyday!!
