What is BEST for you?Just wondering which is the best air intake to change if you have any recommendations, I was thinking of the MST.
Sorry, what is this? improved with Forge carbon inlet to provide more cool air.What is BEST for you?
I think stock airbox is best, improved with Forge carbon inlet to provide more cool air. in terms of flitering & performance. don't want any extra sound + my stock pipe provides already some whistle during shifts.
MST maybe provides +5-7hp extra to standard.
Så härSorry, what is this? improved with Forge carbon inlet to provide more cool air.
We are yet to see a modified GR where Turbo is located behind the headlight and headlight assembly is replaced by big Cone filter or 4'' inlet duct to feed the snail..
More likely than an exhaust, which is not very likely but not non-existent if a failure can in any way be related or blamed on reduced filtering.Does the MST air filter, affect the warranty if you fit it with the Toyota service plan?
anybody making these and selling them ?I use @Helmut Eder 's scoop and very happy with it!
He kindly shared the 3D file, so everyone can print it locally.
Pros:
- keep stock filter
- keep stock MAF tube
- much cooler air getting in the engine at low speeds
- cheap
- choose colors
- WHOOOSH & PSSSSST
Cons:
- requires "post processing" after printing to make it look better and smoother for even better air flow
- would be nice to add a "plug" for flap vacuum hose in the design
I'd take one tooanybody making these and selling them ?
Don' think so, but you can download the file on the link below and have it printed in some local 3D printshop, think it was around 200-250€ in my case for 2 sets.anybody making these and selling them ?
I going for the forge setup soon, with before and after power runs, I have the Collins re-map tooPETG does swell/degenerate above 70°C in presence of moist, FYI
Thanks for the informative reply. I think you may have convinced me to get the Forge carbon fibre onePETG does swell/degenerate above 70°C in presence of moist, FYI
