This is super useful, thank you.Yes it's possible and becoming more common practice. You need 97% pure ethanol or greater ideally. I would keep to less than 1/3 ethanol myself as stock injectors will likely run out of duty at higher concentration.
This is my situation. Curious if open loop tables are self updating.The only exception is maybe the situation where you can only get low quality pump fuel and you want to improve the detonation resistance by adding more E.
I see the followingOn a side note, does anyone know how to monitor injector duty cycle? I don't see it in the OBD2 data and I think this is one of the most important things to monitor.
